Question about Refrigerators
How to make cans get colder in koolatron vending machine
I got the koolatron model # ec - 23 as a gift and it keeps cans cool but not as cold as if putting them into fridge. I keep it in the entertainment room when people come over to visit. I wanted to find out if there is a way to change it to make the drinks colder.
Try this:
Posted on Apr 21, 2012
    Habit-Forming:
    Scholar:
  • 34 Answers
AS I UNDERSTAND IT, THE LOWEST POSSIBLE SETTING IS ABOUT 40 DEGREES F BELOW AMBIENT TEMPERATURE SO OTHER THAN KEEPING IT OUT OF THE SUN OR A HOT CAR, THERE IS LITTLE YOU CAN DO. THE UNIT USES THE PELTIER EFFECT (THE REVERSE EFFECT OF A THERMOCOUPLE) TO ELECTRICALLY MAKE A COLD AND A HOT JUNCTION. RUNNING ON 12-14 VOLTS DC, IT MAY BE SAFE TO MIST WATER ON THE HOT JUNCTION, OR OTHERWISE COOL IT, TO IMPROVE IT'S HEAT DISSIPATION CAPACITY. I DON'T KNOW, I HAVE NEVER HAD THE OPPORTUNITY TO TRY IT.
Posted on Dec 25, 2008
I purchase a koolatron CVF18 Vending Fridge I plug it in and neither the fan nor compressor came on but the power light on the power cord came on
Sounds like the timmer has not passed the defrost cycle, if you look near the compressor unit, you will see a box with wires going into it from compressor and up into the unit, you should see a small dial about 10-15mm diam, turn this dial clockwise, may need a screw driver, should work once turned, If you cant locate it near the compressor, have a look within the unit or ontop for the timer unit with the dial and tun it clockwise, if the unit operates, spray with a good quality lub spray and turn it fully for 5 revs. Should work fine once done....Russ
Aug 12, 2012 | Koolatron CVF18 Coca-Cola Retro...
Compressor/unit runs constantly but does not cool.
is it keeping the inside contents cold and or frozen, if not possibly condenser coil needs cleaning,also if its in a very warm place and you have no problems other than that its just trying to keep things cool and has to run longer to do so
Jul 18, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Cans are not cold enough
Try just unplugging the unit and leave the door open for 24 hours. Your problem is sometimes caused by a heavy frost and ice build up on the evaporator plate behind the dispensing unit. After 24 hours, plug the unit back in, reset the thermostat to the 11:00 position and close the door. I hope this helps.
Apr 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Koolatron vending machine
customer service helpline at 1-800-265-8456
Apr 23, 2008 | Koolatron (785169015699)
KOOLATRON VENDING MACHINE, FAN WILL NOT WORK
Dec 15, 2007 | Koolatron (785169015699)
Koolatron vending fridge
Nov 30, 2007 | Koolatron (785169015699)
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
