Question about DFI CB61 Motherboard
Max ram ?
Hi ;
ı have a dfı cb61, and ı bougth two 256mb pc133 sdram. when ı put them on my motherboard, system shows that there is 384 mb ram.. but there must 512mb.. my motherboard always reduce 128 mb. what can ı do ?
    Scholar:
  • 58 Answers
Max -> 768 MB (3 x 128MB)
see this link:
http://www.memoryxxl.net/index.php/cPath/2293_2294_34196
/category/dfi-cb61.html
RAM Specifications: Standard RAM: ECC and non-ECC, Unbuffered and Registered, Chipset: Intel 440BX Maximum Ram: 768MB Steckplätze / Slots: 3 (3 banks of 1)
Posted on Jan 06, 2009
Hi can I add 2G ram for this mother board
Yes. When the manual was created 1GB pc133 sdram modules weren't available yet, but they said when they did come out that the bios would support them so the max ram you can have is 3GB.
Here is an excerpt from the manual:
System Memory Type/Speed SDRAM DIMM - PC133 Only
Current Maximum Memory 1.5-GB
Maximum Memory 3-GB (when 1-GB PC133 SDRAM
are available)
Memory Parity Not Supported
ECC Memory Supported (Intel 845 chipset does not support
mixing of Non-ECC and ECC PC133 memory)
Here is the manual:
http://h18000.www1.hp.com/products/quickspecs/10946_div/10946_div.HTML
Aug 15, 2012 | Compaq (252608-001) Motherboard
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
List size and number of memory modules in my Dell Optiplex GX240?
Hello
System memory 256MB of PC133 SDRAM This can be either 3 128MB chips, or 1 256MB chip.
Kind regards
Andrea
Sep 27, 2010 | Dell OptiPlex GX240 PC Desktop
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
DELL Optilex GX110 - RAM
Put the "old" RAM back into the computer, to see if the PC will work at all, or if you damaged the motherboard when you were changing the RAM, or if you accidentally disconnected some cables or jumper-blocks.
Feb 03, 2010 | Dell Optiplex GX110 (2909T) Motherboard
My evo is running slow, i was thinking of upgrading the ram. what type of ram and what is the max?
mine was running slow too. Like I'd turn it on and go grub some coffee, than make some toast and then after It'd bring the windows screen on.
If that's the case I suggest to try different hard drive, but my guess it's motherboard issue:
Here is memory information for EVO D51. Please let me know what model you have, so I can be more specific
RAM Memory Specifications
Memory Speed: 133MHz
Memory Type: SDRAM (PC133)
Maximum Memory Supported: 1.5GB
Memory Slots (Total): 3
Oct 08, 2009 | Intel Compaq EVO Pentium 4 1.7GHz / 256MB...
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
DFI CB61 Motherboard Logo
140 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
jason
RajDeep Gautam
RajDeep Gautam
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
