Question about Frigidaire GLEQ642A Electric Dryer
When drying the dryer makes a very load sqeaking sound always
I need to know what makes this sound and i need to know how to get in the dryer and fix it
  • jymypoints Jan 25, 2009
    We have the same problem. The dryer squeaks once per every revolution and only when rotating in a clockwise direction. Also, the squeak diminishes somewhat as the dryer heats up. The noise is at its worst when the dryer is first started.
  •  Sherman
    Sherman May 11, 2010
    what is the make and model number
  • 979 Answers
Check the spindle or axle the drum rotates on. They can be oiled at the pivoting point or turning point. The motor may also be oiled at the axle. You have something grinding in there. Probably metal to metal. Graphite works best as it does not dissipate with heat.
Posted on Jan 28, 2009
Dryer is sqeaking
Hello jodysmomma - Sounds like you either have a problem with the belt, front and/or rear bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replace depending if they are worn, damaged or loose.
Jan 09, 2013 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint dryer making sqeaking noises still dries and rolls fine but noises driving family crazy
There are two main causes of dryer noises: foreign objects in the felt strips, and dried bearings. To relube the bearings, you need to disassemble the dryer and pull the drum. Inspect all bearings, including the belt tensioner.
replace what is damaged by wear.
Dec 13, 2010 | Dryers
GE DBXR463ED2WW dryer making loud sqeaking noise when full load in dryer? What is causing this and how can I fix
there are some pads that are like teflon that the drum rubs on. get some more and re place
Oct 24, 2010 | GE DBSR453EBWW Electric Dryer
When drying makes sqeaking sound
You probably have a bad bearing in the center at the back. Or the support pads could be worn out and its starting to rub metal.
May 21, 2010 | GE Dryers
I have a GE Dryer model type 333/453/473 and I recently noticed a ''sqeaking'' noise near the motor. Does anyone know what might be causing this. Do I need to lubricant something. The dryer still dries...
this noise is usually due to the ideler pulley going bad and should be replaced but until then take the back off and spray the pulley with some sillicone
Aug 23, 2009 | Dryers
I need diagram for LDE9314ACE ,how to replace the belt
http://www.appliancepartspros.com/partsearch/model.aspx?part_id=3988821&&model_id=26265&diagram_id=766843
and
http://forum.appliancepartspros.com/dryer-repair/4155-dryer-making-load-sqeaking-sound.html
I think this should solve your dilemma :D
Jul 29, 2009 | Maytag Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Sqeaking dryer
Find a heat resistant grease. It must say heat resistant. Then you will need snap ring pliers. The rollers are behind the drum, the whole machine must be taken apart, no fun. While apart, vacuum everything. Note how the belt goes before you take it off. A few extra screws while you're in there will expose the fan area. You will be suprised what you can find there.
Apr 02, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
