Question about Whirlpool GEW9250 Electric Dryer
My GEW9250 quit working at all.
I used to be able to unplug it for awhile, and it would work again. Now, nothing works but the inside light. I can't get to the electrical components in the front to see if anything obvious is wrong. HOW DO I GET THE TOP FRONT CONTROL PANEL OFF? I've tried 3 times, and see no visable way to remove it. Please help.
  • diondavis May 11, 2010
    I received some help on my problem with the GEW9250 dryer from jcas1--I was at last able to access the controls. However, everything is still a mystery. By using the diagnostic test [more time, less time, more time, less time in 5 seconds], it came up that everything was alright. After doing this, the dryer worked fine. However, when I came home today the dryer control lock button was beeping on and off as before. Does this mean I have to use the diagnostic test every time I want to use the dryer? And why did this cause it to work?
FIRST SHUT OFF THE POWER..To remove the top cover, look in back for 2 or 3 torqs screws securing the rear of the top panel, slide the top back to disengage. Remove the 3 or 4 screws holding the sheet metal cover to the ERC on the right side. Move it out of the way. Disconnect the ribbon connector from the user interface to the ERC, locate 4 phillips, two on each side of the back of the front panel... My customer's machine would lock up, same as yours. First I replaced the ERC, no change. Then I replaced the user interface. Ran one or two loads, then locked up. So, I replaced both the ERC and the UI, ran 2 loads and quit again. I gave up and gave her her money back.. JCAS
Posted on Dec 27, 2008
It says setup is starting sv. but won't boot . What can I do?
unplug the power cord, remove the battery, with these removed, hold down the power button for 15 seconds. Replace the battery, plug in the power cord and try starting it up again. Hope it helps.
Feb 05, 2015 | Acer Aspire One PC Notebook
Brake lights don't work?
check the bulbs and fuses and brake light switch
Jun 06, 2013 | 1999 Jeep Wrangler
Dryer electrical supply ok but dryer control panel won't come on
If the contro lock is faulty the unit will not start. I think you have identified the problem there.
Please rate my help++++Thanks for using FIXYA
May 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet gew9250 - Control Lock
The most common reason for this type of complaint would be a failure in the user interface board (UI), if the portion of the board has a short circuit across the lock trails it will demonstrate this symptom.
The fix would be to have the UI replaced. Part number is
8558753 Platinum
8558755 Biscuit
8558756 Pewter
The cost for the part alone is around $160.00 plus labor to install.
I know this is not good news. sorry....
Apr 18, 2010 | Whirlpool GEW9250 Electric Dryer
My 2005 Kenmore Elite Smartheat Quietpak 9 quits working now & then & beeps with an echo beep and the lights flash also. If I unplug it & it rests awhile it will work again. Interestingly, it...
There is a model number inside the door frame. If you would post that it would be a big help. What you are describing is troubling though and could be the control board.
Feb 15, 2018 | Kenmore Dryers
Duet dryer: inside light is out, but panel lights work fine. it just beeps when i hit start. i unplugged it for 10 minutes but it still won't work
check the door switch it should be on the top of door frame push it if its not clicking it's probably not working.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
