Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Flashing Control lock light
I have a Whirlpool Duet HT And I dunno how but My brother must of fooled around and now all i see is a flashing control lock like and it wont let me do anything... I have held the control lock butten for 3 secconds like it syes but it still just flahses the light and wont let me do anything... and I have tryed Unpluging it and still THIS.....B..L..I..N..K..I..N..G LIGHT Still stays What can i do to fix it????
  • mdee50 Feb 17, 2008
    I have had the HT for 2 1/2 years and it has worked great for most of that time. About a month ago, we started having problems with the door latch. Now the washer seems fickle when washing a load. Sometimes ot goes all the way through and sometimes it stops with error code fdl or f14 or f22. My mother-in-law called a repair man who said it was a computer problem that will cost $700 to fix. Did we all get a lemon?
  • irene lawson Jun 26, 2008
    why does my machine flash an F
    President:
  • Whirlpool Master
  • 662 Answers
Bottom right hand corner, end of cycle button, hold it for 3 seconds; machine will fix itself. This is the 'child lock device'.
It turns the control lock on, do it again, and it turns the control lock off
Rate me 'very helpful' pl for the free help, thanks!!
Posted on Jun 12, 2010
    President:
  • 1,294 Answers
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Posted on Apr 30, 2007
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
No codes given control light flashing on selector knob but machine will not start
Hello & Welcome to FixYa
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Whirlpool GHW9100L Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Control locked light is on my Whirlpool duet ht washing machine. What can cause it?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
Jun 03, 2009 | Whirlpool GHW9300 Duet Washer
Flashing f11
Hi
F11 is a Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
    It should be the end of cycle signal volume botton
    Aug 04, 2008 | Whirlpool GHW9300 Duet Washer
    Control Lock is on, how do I reset the machine?
    Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
    Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
    To unlock the controls
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the
    CONTROL LOCKED status light turns off.
    Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
    Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
    425 people viewed this question
    Sal De
    Marvin
    Marvin
    Justin Duby
    Justin Duby
