Question about AmbiCom GPS-CF Pro GPS Receiver
0 characters
1 Points
The navigation wont work on my binatone x350 for some reason,everything else works except for this,any ideas?
The software needs reloading, if it is under 12 months old and you have the receipt, contact Binatone on 0845 345 9677 and they will organise for this to be done under the warranty. If the Sat Nav is over 12 months old or you do not have the receipt they can still resolve this for you if you pay £32.99 which will include brand new software and the latest maps available- it's worth it rather than purchasing a new Sat Nav!
Feb 12, 2011 | Toymax Binatone Carrera X350 Car GPS...
My Garmin 265W sat Nav has lost power. Can you advise? Derek Blennerhassett 7 Montpelier Parade Monkstown Road Blackrock Co. Dublin Ireland
put small peace of paper in with power cord in back of unit, it gos bad from vibration it helped mine also keep cell phones far away from unit
Nov 15, 2010 | Garmin Nuvi 265W GPS Receiver
My sat nav map is over 12months old how do i update to new map. my sat nav is medion
OK, what you need to do, is go to the GPS Manufacturers website, download the latest software for your unit and PC. Install this as Administrator. Now connect up your GPS via the USB cable. Then turn on the GPS, then update using this software, Reboot and using it's now, updated software, download, any updates, as may be, from the website, it is all done through the GPS's internal program.
Mar 28, 2010 | GPS Devices
I need to change my emal address
if you connect your sat-nav to your computer, and open tomtom home, click the help button and it should say view manual, or something similar
Jan 04, 2010 | Tomtom GO 720 GPS Receiver
Tomtom won't work
I think that means you do not have a card installed in the sat-nav
Dec 30, 2009 | Tomtom GO 720 GPS
Restarts unexpectedly and slow to start
The TomTom 520 and 720 are the same unit. the differance is the maps. The 520 has maps of the US and the 720 has maps of Europe. Download the free clearflash utility from TomTom and run it a couple of times. This should clear up your problem. Sometimes the mapset config in the map gets full and it has to be cleared.
Jul 20, 2009 | Tomtom GO 720 GPS Receiver
Tomtom go 720
Select a computer voice, not a human voice.
Dont have any? Use TT Home to download one...
Read some info about TTS, text to speech, HERE
Jun 01, 2008 | Tomtom GO 700 GPS Receiver
I need to download the updated map data to a Nav U 70
First, You MUST use the AC power adapter when connecting the unit to the computer. But if you are using the AC power and the message still is the same, try the following:
Note:Because each of these steps is a possible solution to the issue, check the status of the device after completeing each step.
!. Restart the computer
2. Close all applications that may be running
3. Temporarily disable any antivirus software you may be running
4. Reset the Nav-U unit by placing a safty pin or something likewise into the reset channel and hold down for approx. 15 sec.
5. Uninstall Microsoft ActiveSync from the Add/ Remove programs and then reinstall it using the Nav-U DVD
6. If possible, test it on another computer.
The troubleshooting steps listed above should resolve your isue. if not, service may be required.The Sony eService Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony authorized dealer.
May 22, 2008 | Sony nav-u NV-U70 GPS Receiver
Nav-u.exe Exception
By MS Active sync from computer delete file Mounted Volume/my flash/sony/nav-u.exe (the folder SONY is hidden, you must set show hidden files in your comuter first). And then replace old navi file by exe file of total commander CE version ( download is free on site of developer) .You must rename the totalcmd.exe to nav-u.exe. Now after reboot is allowed everything, including executing any other navi software like tomtom, igo, navigon and many other (multimedia players). The oficial navi (old navigon) by sony is not so good in compare with new navi soft. .. enjoy.
Feb 08, 2008 | Sony nav-u NV-U70 GPS Receiver
AmbiCom GPS-CF Pro GPS Receiver Logo
26 people viewed this question
Top AmbiCom GPS Devices Experts
Are you an AmbiCom GPS Device Expert? Answer questions, earn points and help others
