Question about Gateway MX8711 Notebook
DISPLAY PROBLEM I turned my laptop off last night with everything working. Open it up this morning and it boots up but now screen presentation. I can actually see the screen but it is as if no background lighting is there. Any suggestions?
My Acer aspire 5251-1005 laptop has a black screen and will not boot up. It was working fine last night. please help me
Hi , Try to connect to an external Monitor and see if it can display ..This Black screen could be a an onboard video problem or just a simple memory problem.
Sep 29, 2014 | Acer Aspire Computers & Internet
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
Just bought a samsung n145 yesterday. entered password and everything seemed fine. used the password several times last night and it worked fine. this morning when i go to enter password it says invalid...
You can try 2 solutions as mentioned below.
  1. Check in case NUM Lock or CAPS Lock is on, if ON turn it off and try again.
  2. Second, Restart the system and keep tapping F8, You will get a screen for Advance Boot Option. Select Safe mode with networking or Safe mode. Try login in that mode. If logged in successfully, try creating a new account and delete this account as the account has got some problem. Or you can do a system restore.
Sep 17, 2011 | Samsung N145-JP01US Netbook
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
No visual display
It sounds like your graphics card is shot. If your graphics card is a dedicated graphics card, you might be able to get it fixed/replaced; if it is embedded, then you are probably going to have to buy a whole new display screen.
Sep 04, 2008 | IBM ThinkPad T40 2373 Notebook
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Gateway MX8711 Notebook Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
