Question about Olympus Stylus 1010 Digital Camera
Blurred focusing as soon as turned on
I just got this camera today for christmas and I charged the battery and put it in right and also put a new XD olympus card in correct and when I turn it on there is just like white blobs across the screen and it is making little noises like it is trying to focus. It wont focus on anything and Im not sure what to do. ( I also tried putting in the picture card it came with, and it does the same thing). Any help?
Dear Hokiefootball,
Merry Christmas to you,
Have you Check your Macro and SuperMacro setting whether its turn on or not. The function is for closed up shooting. The sound is from the motorized elements and mechanism in the camera for focusing and shutter adjustment, it is normal. Direct your camera to any object and try to press half-shutter until the target become green. Good Luck
Posted on Dec 27, 2008
No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Jan 26, 2010 | Panasonic VDR-D100 DVD Camcorder
Auto focus no longer works. Every time I turn the camera on, I get the ''Please turn camera off and then on again message''. When I do that, it can focus in the default lens position, but as soon as I move...
fast of all happy new year
your problem is only about your cam machanisam which is not adjast at right position you have to open it and rearange rightly.
for this you have to right tools for it or you can go to its service centre near you.
best of luck
Jan 03, 2010 | Panasonic Cameras
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
FINEPIX A340
the only wayi found to make the card accepted is to upgrade the firmware software, this can be downloaded from fuji website, and extract the file and copy it in the initial memory card supplied with the camera, then put bnewly charged batteries or ac adapter and on the camera holding the disp/back button. then it will show the option for the update, and then click ok . after installing ne firmware switch of the camera and put the new xd card on the camera and format the card. this will enable you to shoot inthe new card.
Aug 30, 2008 | Fuji FinePix A340 Digital Camera
Blurred subjects
Fuji uses a 16MB xD card with the camera, which won't hold too many 4 Megapixel photos at the highest quality setting. So you should plan on buying a larger card right away. xD cards are currently available as large as 1GB, and I think 128MB is a good starter size for most people. Be warned that xD cards tend to be more expensive than CompactFlash and SD cards.
Jun 05, 2008 | Fuji FinePix S5000 Digital Camera
Blurred pictures
Batteries don't play a role in it. Maybe it has slow focus. Try to push the shooting button to only half of its full push, wait a while until it focuses an then shoot by full press on the shoot button. You can also check if you have not switched on macro settings (flower in frame). If you do, turn it off.
May 30, 2008 | Canon PowerShot A530 Digital Camera
I have a camera battery question...Kodak M853.?
Hey cambameriezz,
I would make sure I purchased the correct battery, and if you did I would make sure the battery terminals in the camera are clean by cleaning them with a soft cotton swab. If none of this works I would try charging the camera using the ac adapter rather that plugging it into the computer.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Kodak EasyShare M853 Digital Camera
Autofocus not working
When the camera is OUT OF FOCUS, these are the steps that you could try:
1 Power Reset
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
2 Distance
- When the distance between the camera and the subject is too close,
the strength of the light can cause the picture to overexposed and
be blurred. On the contrary, if the distance is too far,
the beam is too weak to shed enough light on the subject.
Allow yourself enough space between you and your subject.
3 Shutter
- If you press the shutter before the flash is fully charged,
the flash will not be able to emit enough light and therefore
the image can be blurred.
4 Surrounding Light
- Use the fill-in flash mode to create a balanced shot when
the surrounding light is very bright.
5 Backlight
- Use the backlight control feature when the background
is brighter than the subject.
6 Cleaning
- Clean the lenses with a smooth piece of cloth.
7 ASR (Advanced Shake Reduction)
- Put in ASR mode to prevent any blur
8 Master Reset
- Press on MENU button
- Press on the right button until you see SETUP
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds for changes to be saved
* If it still does not work, you need to send the camera for repair.
Just contact the Manufacturer so they could tell you how to send camera safely.
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Photo is blurred and distorted
It is possible that this is a CCD issue, and may be subject to a recall by Canon. Take a look at: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819 for more details about the recall.
Mar 11, 2007 | Canon PowerShot A75 Digital Camera
Olympus Stylus 1010 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
