MY COMPUTER DOES NOT SEE THE CD-ROM
THE CD-ROM IS NOT SEEN WHEN I OPEN MY COMPUTER. ON THE DEVIVE MANAGER , FOLDER, WHEN I TRY TO SEE THE HARDWARES THE CD -ROM IS NOT RECOGNIZED
  • 1 more comment
  • tally za Dec 26, 2008
    device manager sees my dvd RW but xp reports it as a CD or DVD ram please help.
    XP
    Liteon DVD RW
    Gigbyte motherboard
  • Anonymous Jan 06, 2009
    my computer does not detect my cd's
  • tally za May 11, 2010
    thanks for the suggestion, but it did not work. no conflicts are reported, the device manager correctly identifies the drive. If i put a cd into the drive, the device reads it, it even seems to read some dvds. just got a new game - it shows the drive as dvd-ram and will not read the disc??
My cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Posted on Mar 24, 2009
  • 48 Answers
Check to see if this post will help you
Posted on Dec 26, 2008
I installed win7 my asusm51va computer and cd rom is has been no seen and dont work what can i do?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 09, 2011 | Computers & Internet
Tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 | Computers & Internet
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
<SPAN style="FONT-FAMILY: 'Courier New
Hp dv6917cl - dvd drive not seen under vista 32
you can try deleting the upper and lower filter.
follow the below steps
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Aug 06, 2011 | HP Pavilion dv6917cl PC Notebook
Computer does not see cd wp system
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Nov 23, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
This dvd writer can read and write dvd, cannot read and burn cd
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
or it might be a registry problem you did mention if you could see this dvd burner in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 17, 2010 | LG GH22LP20 DVDRAM Burner
How do I open a cd to transfer it to my pc? I have my resume on a cd that someone made for me using his laptop, When I go to My Computer, there isnt anything that shows that it is recognizing the cd drive,...
Put a store purchased CD or dvd in the drive and see if it is seen by computer.
If so, remove it and place your cd in the drive.
If you get a message, format not recog., find out what format or was used to copy cd.
If you are useing VISTA and wish to view a doc. made on a win98 machine, you will have problems.
If the cd/dvd drive is not seen under mycomputer, you may have a damaged drive or may need to reconfigure it to be seen by your computer.
Check your jumper settings on the drive.
But first try a new disk and see what comes up.
Oct 05, 2009 | Computers & Internet
Hp cd rom dvd drive
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself, just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit, then boot your system properly again.Then when the system boots, just right click on my computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your drive is there, then just right-click on it, and select uninstall, and after this, on that same page, click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the "Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Jul 19, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Where can i get driver
use things like driving detective or something. it automatically gives you updates for your hardwares that needs updates
May 20, 2009 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
CD rom drivers problem.
hmm...in device manager, are they both 'clean' meaning without any marks on them?
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
798 people viewed this question
Alun Cox
David Payne
David Payne
