Monitor colorization problems
I got a new LG monitor and I installed it, but I can't figure out why my monitor is rose tinted. All the settings are correct, but the screen is still rose tinted.
  • May 11, 2010
    Did you have this problem before you replaced the monitor? Is your new monitor really "new" or just a different one? And is this a CRT or LCD monitor?
    Problem Solver:
  • 11 Answers
1.) Check to see if the screen has a peel-away, cellophane type shipping protector on it ( transparent with a rose color tint ? ). 2.) Click Start >> Control Panel >> Display >> Settings >> Advanced. If this section has a tab labelled "GAMMA", you can manually adjust all display settings. 3.) If no gamma control is available - download one FREE ( Dark Adapted ) here >>
http://www.aquiladigital.us/
Posted on Jan 29, 2010
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Subtle Two Toned Split Screen Color Difference.I think I hit some button by accident. Monitor is great but now I have a split screen where the left hand side of the screen has a lighter tint than the right...
Hi. I have got the same problem, and it was very easy to solve. Monitor was LG. The problem was not in the system, it was in the monitor. I just clicked the buttons on the monitor, it was on the wrong setting that divides monitor in two colors, so if it happens to you, try checking your monitor settings, mine was set to "demonstration", half was lighter than the other one, just set it to usual or user. Keep in mind the settings are on the monitor itself, not in the windows (buttons on the monitor itself) Good luck.
May 10, 2012 | LG 22" FLATRON LCD Monitor
After a vacation I returned and now my monitor has a rose colored tint to everything.
If you havent already done it check that the connection between your monitor and computer is jacked in full. One of my own monitors tend to shift in yellow and rose if the connection is'nt full.
Aug 25, 2010 | ViewSonic Computers & Internet
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
LG 17" flat screen monitor one old, all red is gone from display
Did someone change the setting on the monitor itself ? check those settings and then check the setting on your graphics card, sometimes you can change those setting and it will effect the color that you are seeing
Oct 09, 2009 | LG Flatron F700P 17" CRT Monitor
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Red tinting with the Acer LCD monitor AL1916
Amazingly enough my monitor did the same thing and while looking for the serial number the problem got resolved. Since I don't know exactly how it got fixed I will tell you what I did. I turned the monitor off, removed the power cord from the unit, turned the surge protector off and back on, placed the monitor face down on my chair to read the serial number, reconnected the power cord and turned the unit back on. The problem was fixed. Go figure.
Nov 16, 2008 | Acer AL1916W 19" LCD Monitor
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
142 people viewed this question
Alun Cox
David Payne
David Payne
