Question about Refrigerators
Need parts diagram for scandinova fridge LF111D to find out which
My fridge has stopped working. The light comes on, but nothing happens and no cooling is taking place. I have been led to believe that it may be the thermostat but, before committing myself to buying a thermostat I would like to investigate the ''innards'' of my fridge to see if it belt, brushes, motor, compressor, etc. To do this I would like a parts diagram so that I can identify my method of ''entry'' and also establish what the cause is before I lay out cash for spare parts - or, in fact, a new fridge. Can you help me please? The fridge is a larder fridge Type LF111D. Serial number 71700583. Thank you. N. Stanley
To test the stat short out the wires and see if the compressor operates and cools the fridge.
Posted on Jan 06, 2009
Why does it turn on and off in seconds?
Hi Sonu,
  • The Overload Protection may be defective, Check and replace.
  • Also Check the Defrost Thermostat Timer, It might be stuck on Defrost. Replace if needed. I include a link to diagram & parts.
Good Luck,
JP
FRIGIDAIRE REFRIGERATOR Parts Model FSC23F7HSB1 Sears PartsDirect
Jun 25, 2015 | Frigidaire FSC23F7HSB Counter-Depth...
Whirlpool gs6shaxls03
If the inside light comes on and still nothing then you will need to check the=> ยทSee page 16 of the parts manual=> GS6SHAXLS03.pdf(1153.91 KB) and in the photo location # 6 That is a electronic defrost control which if it goes bad can stop cooling and the inside and outside fans. Click Here for part=> 2213489 Adaptive Defrost Control I am here if you need me, Thanks John Tripp Appliance 911 Or the same part=> HERE
ADC Control Parts for Whirlpool GS6SHAXLS03
Jul 31, 2014 | Whirlpool Refrigerators
Fridge freezer not working
If its a whirlpool side by side ou a kenmore then good chance it a thermostat. Turn it off and back on, if nothing happens check timer.
Aug 19, 2012 | Refrigerators
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
The top half of the freezer does not work
I have a Scandinova chest freezer and the left hand side froze, but not the right side, because the compressor in the box under the right side of the freezer was getting so hot, a small amount of heat was conducting back through into the right side of the freezer and preventing anything on that side from freezing!
I solved this problem by running the compressor outside of the of the freezer box, by taking the air vent off, unbolting the compressor and then pulling out by about 20cm and running it from there.
Aug 22, 2009 | Freezers
Hello nordictrack has just stopped
Sometimes when these machines are assembled
a wiring harness gets damaged. If you have a manual, look at the diagram that shows the upright columns where the upper console mounts.
Look for the wiring harness coming out the top or bottom on the diagram. If it is on the right, the take the screws/bolts out of the arm that mounts to the upright and lift it up, just a little to see if the wiring harness is damaged or partly disconnected. If you cant see anything, then it is time to call a tech out to troubleshoot the problem.
Jul 07, 2009 | NordicTrack E4000 Treadmill
Scandinova fridge freezer. Fridge works, but the lower freezer section only freezes when on fast freeze. Any ideas? We live in Australia but the unit was purchased in the UK. Do you know in which country...
When on fast freeze the freezer thermostat is by-passed and current sent directly to cooling gas compressor. I suggest the freezer thermostat is knackered, fitting a new one isn't too difficult, that is if you can get your hands on one out there !!!!
Unfortunately I don't know where Scandinova are made, or more to the point IF they are still in production but, some replica spares are to be had.
Good luck.
Oct 30, 2008 | Refrigerators
Refrigerators Logo
583 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
