Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Replacing bad caps
What is the difference between a 450wv cap and a 450v cap?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Http://www.flickr.com/photos/byziol/3199699625/sizes/l/
List of caps
Where to get them 450WV replacement
Posted on Jan 16, 2009
  • Astar Master
  • 5,569 Answers
Mostly a matter of preference; the working voltage of a cap is the maximum it should be subjected to continuously; some capacitors are rated with an additional 'Surge' rating, the voltage they can withstand now and then without self-destructing. Those intended for use as decoupling caps or to smooth DC voltages, will have clearly marked polarities which are important and installing them backward can produce a surprisingly loud 'pop' and scatter aluminum foil and paper scraps for a few feet.
If a cap has only a 'V' (such as 450V) after the rating, you can safely assume it is DC or direct current voltage. Most caps are marked with either V/DC or V/AC and while one marked AC can be used with static voltages (DC), one marked with VDC is not normally suitable for use with alternating current uses. Caps marked with AC ratings are used for motor starting and other AC-only applications and actually may be subjected to peak voltages well beyond the stated rating.  Some AC caps will bear a symbol indicating which lead is connected to the outer foil since this can be important in some applications where the outer foil can serve as a shield.
Posted on Dec 25, 2008
Not much. V means "Voltage" and "WV" means "Working Voltage".
V means peak voltage that the capacitor can handle. WV means the normal voltage it can handle, but it can handle brief spikes higher.
As long as they're the same type (tantalum, electrolytic, etc) and oriented the right way, and at the same or higher working voltage, you should be fine.
Will a 16uf 450v generator capacitor work in place of a 12uf 450v generator capacitor
Yes it will. The key is to not go lower in capacitance or in rated voltage. As you go up in cap size the cost will also go up so you want to stay pretty close to rated value unless dinero is no object.
Aug 06, 2015 | Coleman Heating & Cooling
450V 150UF WORK SAME AS 450V 68UF
no you could use a cap with the same UF rating and higher voltage without any issues but the uf rating must be the same.
Apr 06, 2013 | Televison & Video
Check engine light stays on
The 'check engine' light comes on when almost anything goes wrong, from a loose gas cap to computer systems; low fluid levels to a bad catalytic converter. A common problem is the gas cap not screwed on correctly. This has an easy remedy. Screw the cap off and then carefully seat it and screw it back on until you hear it click. Then drive the car for at least 100 miles. If the light goes out that was the problem.
If the light stays on then you must take it in to be checked by special equipment because that is the only way to isolate the problem.
In my own experience of the light coming on 3 times, there were 3 different reasons: 1) loose gas cap, 2) bad catalytic converter needed replacing [the most expensive unless under warranty] and 3) a bad gas cap that needed replacing. After all 3 instances, the light went out.
I hope it's only a gas cap issue for you. Good luck.
May 24, 2012 | 2005 GMC Envoy
I have a problem i just replace 2 capacitors 10uf 450v and imagen come but after 20 sec. the others one cap blue 10j 3kv just burn, what i have to do?
Are you saying there is a blue 3 kv rated cap in the unit? Most LCD sets (that is what is listed here) do not have any caps rated that high voltage wise.
You would need to id that cap---3 KV means rated at 3,000 volts and usually will be markings like 104 j etc
If different model/brand than indicated here let me know.
that cap will have a location number printed on top of the board next to or under it like C706 etc.
May 22, 2012 | Acer AL2416W 24 in. LCD Television
My polaroid when turned on after a few secs the screen goes black but the volumes still works
Bad caps in the power supply. 10 uf 450v be careful these caps really hold a charge.
Nov 20, 2011 | Televison & Video
I have a acoustic solutions CTVL32W3HD television,It has no picture but sound is working fine It has a red flashing led on the power board, I changed the 2 10uf 450v caps that were bloated , no difference
The two caps you changed are the typical solution for this problem. Maybe there's a problem with the inverter board.
Check to see if there are any smd fuses near those two caps that you replaced. Then resolder the transformers on the inverter board. You'll probably find some more smd fuses on the inverter board. Check them and tell us the result.
Apr 08, 2011 | Televison & Video
I have sound but no pic on my polaroid hd tv model number tda03211c there is also a red light blinking in the back of unit when it is on
Hello; I am John at J D Electronics in Poland Maine. I have had a few Polaroid model TDA03211C in my shop that would show Polaroid on screen and then loose the backlights. but not always, but would still have sound and remote control abilities. Many of these Polaroids and Memorex 32" sets have the same design. There is the main board in the bottom of the large metal box with the power supply/ ivnverter board in the top. On a few of these I found opened Caps to the right of the 2 large ivnverter transformers on the left. These were labeled EC17 and EC18. They are 10ufd @ 450V and 105 degree C. Replacing these 2 caps has now fixed 3 of these sets. John
Apr 08, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Black screen on Zenith plasma tv's
Hello, My name is Dave and I can help you fix your Plasma TV. Give me a call. Feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Dec 23, 2008 | Akai PDP-4247 Television
TV won't turn on
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Dec 02, 2008 | TruTech PLV16320 Television
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
492 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
