http://www.pdagold.com/articles/detail.asp?a=246 just click this linkand for instructions
How to install a different language ROM in you PDA iPAQ 3900 series.. 1.- Download the last ROM update for iPAQ 3900 series. 2.- Using Winzip, unpack the ROM update file. 3.- Run the program update utility until it asks to push the upgrade button. 4.- Without leaving the utility, open the .NBF file extracted from iPAQ update. for 3975 English series is: NK_Windsor21010WWE.nbf for 3970 Spanish series is: NK_Wisr210_14_ESP_BT.nbf for 3955 English series is: NK_Windsor11010WWE.nbf for 3950 Spanish series is: NK_Wisr111_01ESP_NBT.nbf 5.- Hex edit that file and you will find something like: For 3975 English series.- iPAQ 3900-WBT-ENG-2.10-2CF4... For 3955 English series.- iPAQ 3900-NBT-ENG-1.10-9673... 6.- Replace "ENG" with your current country code ("SPA" for Spanish, "FRE" for French, "GER" for German...). 7.- Replace the hex checksum value for the correct country checksum (see tables below). ie: To change a 3970 from Spanish to English, change the 2cf4 for 2cfe for more detailed instruction above this click this link http://www.tweaks2k2.com/How_to/39xxROMlang.htm ================= you can switch the language. But it is not easy. Especially with the new iPAQs it is hard to do, because HP did lock the previous possible ways of doing that. I have never done this but all I know is that you have to download the ROM update from HP website, use hex editor to alter some data in the ROM file so that the loading software thinks that it is the proper file for your original PDA language. Probably you have to find and change a string which equals to the language name. If your iPAQ has for example french ROM, you have to download english ROM from HP website and then change the ROM ID to french one.
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? ...
(More)
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? I am worried if the phone quits I lose the use of my PDA and all my info. Help
Phone works fine if you use keyboard on outside of case. When you open phone, LCD screen displays...
(More)
Phone works fine if you use keyboard on outside of case. When you open phone, LCD screen displays whitescreen permanently across entire LCD.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
