Question about SanDisk Sansa Clip MP3 Player
Guide? Help! Older person needs a guide to 1)go between menus; 2) select songs to go on 'walking' or 'listening'; 3) how to load; 4) basically everything! Thanks so much! Goblca
  • 8,596 Answers
Here is a link to your user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How to download a song?
I don't know where you want to download from but i will tell you how to it from youtube,
1. go find a song you like on youtube
2, once you have it then pause it and go to the top and put "ss" in front of where it says youtube
that will bring you to a download page
3. click on download then the music video will be in your windows download folder. just click it and it shound open up and play
the only thing is you would have the video there but there are ways to just use the audio
Apr 15, 2017 | Audio Players & Recorders
Tip
How to Edit Ringtone to iPhone 4
AVS Ringtone Maker is a powerful ringtones maker to editor and creator. It is a program which will help you to make a bright and short ringtone from your favourite MP3 musical composition to your iPhone.
This Ringtone Maker supports available interface and tech-support in English, French, German, Spanish and Italian. So no matter where you are from, you can use this software to edit ringtone to iPhone, either. Meanwhile, it supports all iPhone types including iPhone 4.
Tired of buying iPhone ringtones from iTunes? Well, here's your solution. You can completely edit your personal ringtone to your iPhone by following the guide below.
OK, no time to waste. Let's find the fast and safe way to edit ringtone to iPhone 4 together. Find something useful for editing ringtone to iPhone 4 now.
Guide:How to Edit Ringtone to iPhone 4
Steps as follows shows how to edit ringtone to iPhone 4 with the AVS Ringtone Maker.
Step 1: Install and run the software to input the file.
Step 2: Pick the songs you want to edit and listen to it before you create your personal ringtone.
begin to edit your ringtone to iphone 4
Step 3: Trim, cut out the needed part, and delete the unnecessary parts, then click the "Save" buttom.
save the ringtone that you have converted just now
That's all.
With this smart iPhone ringtone converter, you can get edit iphone 4 ringtones easily and quickly. You can make and transfer personal iPhone ringtone just in a few minutes. Come and have a try now!
Connected information : iphone ringtone blackberry ringtone mp3 ringtone music converter
on Jul 15, 2010 | Computers & Internet
Tip
Wii soft mod guide
Wii SoftMod Guide 3.1 - 4.1
Before we start into the process, you will need an SD card, at most 2gb capacity. This SD card will need to be formatted into FAT32 format.
Note: If you are on Wii System Firware 3.1, 3.3 or 3.4 You need to be connected to the Internet, unless you know the proper steps to upgrade using the Wii System WAD and Firware Updater 4.1 which I may include later.
First, download this file pack. Wii SoftMod 3.1 - 4.1 Pack
Download Readme file here. Wii SoftMod Readme
Step 1. Install The Homebrew Channel & BootMii
1. Put all the files from ‘Wii SoftMod 3.1 - 4.1.rar’ onto the root of the SD Card.
2. Insert the SD card into Wii.
3. Go to Wii Options, then go to Data Management > Channels > SD Card, then you will get a message saying "Load boot.elf?" , select 'Yes' and the Hackmii installer will run. (Goto the Channels first, then insert card or your console might freeze)
4. Install Bootmii as boot2 if you can, if not then install it as an IOS then go back and install the Homebrew Channel.
Step 2. Install Recommended CIOS
1. Go to Homebrew channel and run Trucha Bug Restorer, load IOS36, press 1, read the warnings then select 'downgrade IOS15', select to load IOS from SD card then let it do its job, keep an eye on what it is doing and make sure you select 'load from sd card' when it asks & don't get any errors.
2. Run Trucha Bug Restorer again, this time select to load IOS15 on first screen using dpad left/right, then select the IOS36 menu & install patched (select 'yes' on all 3 patches) IOS36 to slot 36, again using IOS from SD card.
3. Run Trucha Bug Restorer again, load IOS36 and this time select restore IOS15.
4. Run cIOS38 r14 installer, select IOS36 as the one it should use and then select wad install.
5. If your Homebrew Channel flips upside down then continue with the guide and when completed reinstall the homebrew channel.
Step 3. Update System Menu (Only for 3.1, 3.3 or 3.4 Firmware) Note: Internet Connection needed
1. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1.
Step 4. The Final Step
1. Go to the Homebrew Channel and run Wad Manager 1.4 and load IOS249 (Default) and SD card.
2. Instal the following IOS.
* IOS38-64-v3610
* IOS50-64-v4889
* IOS53-64-v5149
* IOS55-64-v5149
* NeoGamma r8b17
Restart your console and your finished!
on Feb 18, 2010 | Video Game Consoles & Games
I have a Nokia E51, which has a theme song for incoming ring tone and I would like to remove it for the normal ring tone, can you help? Cheers Daryl
HERE IS THE STEP BY STEP GUIDE TO CHANGE RINGTONE FOR NOKIA E52.
STEP#1. ON YOUR FIRST MENU GOTO PROFILE SECTION.
STEP#2.SELECT THE PROFILE YOU USE MOST.
STEP#3.CLICK ON IT AND SELECT OPTION CUSTOMISE PROFILE.
STEP#4.SELECT RINGTONE OPTION.
IT WILL SHOW YOU ALL AVILABLE RINGTONE SELECT THE ONE YOU LIKE MOST.
NOW YOU DONE.
Jan 26, 2011 | Cell Phones
My DVR receiver is recording programs that i originally did not put on the schedule. My receiver is also showing the programs in the guide and my daily schedule as "No Info Available". I have...
Hello! For these issues, here are a few simple steps:
First, for the DVR recording shows, you just need to delete those timers. They may have accidentally been set up.
1. Menu, 7-Daily Schedule
2. Timers
3. Edit list
4. Select any timers that you did not create, or want deleted. This will stop them from recording!
For the program guide:
You just need to download the program guide. Here's a couple easy ways:
First way:
1. Pull up the Guide
2. Press 999 then the right arrow button (Browse) until the guide prompts a download,
Second way:
1. Pull up a menu. Press 6 (Sys setup) -1(Installation) - 1( Point dish)
2. Highlight and select Check Switch on the upper right
3. Select test at the bottom left. (If a message comes up between steps 2 and 3, select yes. )
4. Press VIew live tv, and allow the Acquiring signal message and the guide download to go through.
I hope these steps help!!!
Becki Barned
DISH Network Customer Service
Jan 13, 2011 | DISH Network DISH-2800 DTV Receiver
Hi I have windows7 on my laptop. I am unable to remove songs from my Scandisk. Media player also should be latest. Can you guide me how to remove or add songs in my e260 .
By pressing and holding the Select button while listening tomusic, the player will automatically detect whether the current song isalready in the "Favorite List" and guide you to add/remove the songfrom the Favorite list.
STEP 1 - Enable "Advanced mode"
1. From the Main menu, select Settings > Advanced
2. Select On.
STEP 2 - Add song to the "Favorite List"
1. During music playback, press and hold the Select button.
NOTE: If the song is in not in the list, a confirmation message for adding the song to the list will be shown.
2. To add, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
STEP 3 - Remove a song from the "Favorite List"
1. During playback, press and hold the Select button.
NOTE: If the song is already in the list, a confirmation message for removing the song from the list will be shown.
2. To remove, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
Feb 26, 2010 | SanDisk Sansa e260 MP3 Player
I've been putting music onto my mp3 player (Sony NWZ-A818), so it's been plugged and unplugged from my computer quite alot. Whilst I was listening to my music... little white rectangles covered up the...
Windows Explorer
1 Connect the Sony Walkman to the computer with the device's USB cable.
2 Click "Start" and "Computer." Double-click the Walkman icon in the "Devices with Removable Storage" pane and then open the "Storage Media" folder. You'll notice a variety of folders, including Music, Pictures and Video.
3 Navigate to the folder containing the songs you want to transfer to the device.
4 Select your preferred songs and drag them to the Music folder in the Windows Explorer window.
Windows Media Player
1 Connect the Sony Walkman to the PC.
2 Launch Windows Media Player.
3 Click the "Music" button in the Library navigation pane and select each song you want to sync to the player.
4 Click the "Sync" tab on the toolbar and then drag and drop the selected music files into the Sync List pane.
5 Click the "Start Sync" button to transfer the songs to the Walkman.
Media Go
1 Connect the Walkman to the computer with the USB cord.
2 Open Media Go.
3 Click the "Music" button in the Library pane and select the songs you want to transfer to the device.
4 Click the "Destination" drop-down menu and select the Walkman option.
5 Click the "Add To" button to sync the files to the player.
hope this helpful.....................
Jul 31, 2017 | Sony NWZ-A818BLK Digital Media Player
Make the ringer louder I cant hear the phone ringing
Hello. From the User Guide:
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press > to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5.
This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press > to select one of the options: Medium, High, or Low.
4. Press OK.
For your reference, here is a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Thanks for using Fixya.
Sep 29, 2009 | HP Officejet 4355 All-In-One InkJet...
Need help starting
All iPods require that you use iTunes to manage firmware and load songs for playback. You cannot use an ipods mass storage area to load and play songs. You can load them, but you can't play them.
iTunes is free for both Mac and PC at www.apple.com
This will also walk you through the setup and start guide for your iPod.
Apr 08, 2008 | Apple iPod nano 3rd Generation
SanDisk Sansa Clip MP3 Player Logo
102 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
