Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I just received kodak 5500 printer and error message paper jam
There is not paper jam. I just opened the box and turn it on
I cannot send a fax, it goes & then on the confirmation page I get an error under results. please HELP.
Posted on Dec 26, 2008
Kodak all in one 5500 states paper jam. Nothing works on it.
Nothing will work until you clear the paper jam. Even if there is no paper jammed, you need to open all the access doors and then close them again. The machine will do a reset cycle and then clear the paper jam message. If that doesn't work, then there is indeed a small piece of paper in there. Whenever you get a jam and yank a piece of paper out of the machine, you should flatten it out and verify there is nothing left behind and no bits missing..
Mar 24, 2016 | Kodak Office Equipment & Supplies
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Paper jam, paper is jammed below roller cannot reach
Please try this approach to release the paper jam.
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Check the cartridge area for any obstructions in the paper path. Carefully remove the paper jam. Avoid tearing it or leaving torn pieces as it could cause future paper jams.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  6. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem si fixed.
Sep 26, 2011 | Lexmark X6675 All-In-One InkJet Printer
It said to open from cover and remove paper I did and It dont work
If you receive an "Open front cover" error message the solution is to open the cover and remove the paper and any remnants of the paper jam. If there is no obvious paper remnants jamming the printer and you continue to receive an error message I would suggest unplugging the printer from the power source.
After 5 - 10 minutes plug in to power source.
Turn on printer.
See if this has resolved error message. If not you will need to check more carefully for paper remnants that would be causing the printer to detect a jam.
Trust this is helpful. :)
Dec 08, 2010 | Konica Minolta PagePro 1390MF All-In-One...
KODAK ESP 7 AIO Carriage stuck on left handside Paper jam message but no paper or bits stuck inside Have tried reset procedures of internet tried when -feed rollers turn but carriage cradle appears...
optical encoder is known as the timing Strip film that guide the carriage of the cartridge, you have to clean softly with a cotton and alcohol.
Oct 30, 2010 | Kodak 5500 ALL-IN-ONE PRINTER
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Turned it on and it says paper jam. There is no
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
211 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
