Question about Toshiba Satellite A100-S8111TD Notebook
I have a toshiba laptop equium a100-147
I put my laptop away forgetting to shut it down ( i know Doh!!!!! ) it went into the hibernation stages etc when opening it today and powering up the system came on for about 10-15 mins, it then went and hibernated again while the battery and mains were still pluged in. itnow will not turn on and there is no charge registering on the small lcd display in the bottom left,
  • aidplus Mar 23, 2009
    Toshiba A100 wont come out of hibernation after fixing password problem in BIOS (this wanted a password when one wasnt set in the first place) Then when the cleint took it home, the hibernation message came up and it shut down. Nothing ca nbe dome at this point. Removing the battery and even shorting out pad500 does not help in any way. Leds at bottomblinks at times when powering up with battery in place. No action whne plugges in. HD is good.
How do i test the power button on a toshiba equium l40 laptop
OpenControl Panel, Power settings, Advanced Power settings, change SLEEP to Never, Hibernate to never. Shut down and unplug, if you use mostly on AC, remove battery, your laptop when not in use. It will last longer, if there is a power surge not be damaged, and a reboot every day resets the computer.
Dec 26, 2012 | Computers & Internet
Cannot get my Toshiba L505 Laptop out of Hibernation mode
you may find this helpful try it soon and let me know if it works
click here
May 16, 2012 | Toshiba Satellite L505-S5966 Notebook
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
My Equium A200-1V0 fan stopped working
Hi, just thought I'd let you know that when I got my Toshiba Equium 200-1V0 it was supplied with the User's Manual A210 Series. The manual is just basic and does not go into full depth of how to clean out heat sink etc. The problem you described regarding the shutting down is most probably that the heat sink is clogged up with dust and needs to be cleaned. Toshiba has a lot of laptops (different models) with this problem. I had the same problem with Toshiba A200-1V0 and have now got the same problem with the Toshiba A300D-20R which is only 6 months old! On the A200-1V0 I managed to hoover the bottom of the laptop where the fan is and it worked fine, but with the A300D-20R it has not worked, but fortunately it's still under guarantee so I will be sending it back to Toshiba to do it. Here is a link to download the Manuals. You will find the Manual for A200-1V0. Hope this helps. http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Mar 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
My toshiba equium A110-233 malfunction
try removing the battery and power adapter for a few minutes then plug in just the power adapter and boot up. then shut all down and put in battery and adapter and see if that helps.
Jan 02, 2010 | Toshiba Computers & Internet
Problem with Toshiba Equium Laptop which is switching itself off. even when connected to mains supply Is this a problem with the switch or power supply? Hope you can help thanks
If the laptop shuts down and won't boot up straight away, then the problem could be an overheating CPU problem. It could be a faulty fan and/or the fan and heatsink assembly is clogged with dust.
Check the fan and if it has stopped spinning then replace it and if the fan and heatsink is clogged with dust, loosen the dust and remove it.
Sep 28, 2009 | Toshiba Equium 3300M PC Desktop
Laptop equium l10
Hi, My Name is Henry. I am one of the technicians here.
You need to upgrade your bios. Go to the http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click download and follow the instructions.
NOTE THAT YOU HAVE TO BE VERY CAREFUL WHEN UPDATING THE BIOS BECAUSE YOU COMPUTER MAY DEVELOP MORE PROBLEMS IF YOU DO IT WRONGLY.
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Mar 17, 2009 | Toshiba Equium 7100S PC Desktop
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
120 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
