Question about Onkyo TX-SR674 Receiver
Flickering (fuzz/signal Loss) when using HDMI plugs
I have the following hardware: TX-SR674 Samsung N-S4095D AppleTV
Then using the AppleTV through HDMI I get flickering (looks like static) on the screen at random times.
  • 14 Answers
SOURCE: HDMI audio source issues with television off or set to different source?
It is related to the tv, modern tv's have the ability to control different devices through the infra red pick up on the tv, and pass it through the hdmi cable back to the component.
Sony call there remote link Bravia link.
Check your manual for that, If it doesn't tell you anything, then don't worry about it, if it is in the manual then see how to switch it off.
Posted on Dec 13, 2007
robotek
  • 1512 Answers
SOURCE: Power Loss Onkyo TX-SR674
Hi LuckyLady1
Yes, some units lose their presets quickly with the power disconnected. Most lose all memory presets within 10 days. They are designed this way. You may have to get someone in to sort it out for you if you cannot do it. Or ask me for a chat session and I can talk you through it. :)
regards
Graeme
Posted on Apr 09, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
smarthome2
  • 1114 Answers
SOURCE: Suffering picture loss
If you must use HDMI, you need to run it directly to the TV from the source for video and use optical or coaxial digital for audio thru your receiver. The problem is HDMI firmware (which is not upgradeable) you have either version 1.1 or 1.2 or 1.2a. All have issues. Three years and running and HDMI still can't get it right! In techno terms it's a DHCP compliance issue (in the real world it's copyright protection) Unless your TV is larger than 50", you can run Component without any visual loss, the human eye can't detect it. Also, if your TV is older, chances are it's 1080i not 1080p, so, if you set your TV to 720P, which is the native resolution of 95% of all TV channels now, and it looks better than 1080i
(1080i = 540p)
I've been doing Home Automation now for 15 years and I've had the luxury of dealing with VGA, DVI, and now HDMI.They have all had issues. Personally I'm just as happy with Component 720P, just use good cables. Hope this helps the pain! If you need any more help, just post a comment and I can help some more.
Posted on Jun 23, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
HDMI flashing screen on Onkyo TX-SR674 receiver need advice on how to solve this problem
Hi Zach, you can try the following reset as this might be a glitch in the processor.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Feb 21, 2015 | Onkyo TX-SR674 Receiver
Akai LCT3785TA HDMI Not Working with my AppleTV 3
Have you made sure you are plugging the HDMI into the right HDMI port? Many TVs have multiple ports and you can usually use the remote to switch to the proper one. Once you find the "input" menu on the TV you an run through all of then until you find a signal, or look at the HDMI port number on the back of the TV and then select that port. I do not think it is an issue of getting a better calbe.
Other possibility is that the Mac is not sending a signal - and for that you need a Mac person.
Jan 13, 2014 | Akai LCT3785TA 37 in. LCD HDTV
Onkyo tx-sr674 loss of picture and sound
Change the HMDI cable, might fix the problem, intermittents of this type are very difficult to trouble shoot.
Mar 12, 2012 | Onkyo TX-SR674 Receiver
The picture via my Onkyo-sr674 has degraded
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Jul 10, 2017 | Onkyo TX-SR674 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Hi LuckyLady1
regards
Graeme
Apr 09, 2008 | Onkyo TX-SR674 Receiver
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Onkyo TX-SR674 Receiver Logo
373 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
