Question about HP Deskjet D2360 InkJet Printer
Brother DPC 130C
This thing jammed despite the advice on deplay i bravely followed.
Strange! It keep saying i should open back and remove paper jam but there, ofcourse, nothing there. It keeps making strange noices.
Am sure there is something i can do about it, just dont know how.
can you help?
Thanx
checkitright
  • 1362 Answers
SOURCE: paper jam NOT
Try this, remove all paper and bins.
then get alcohol and a clean cloth, clean all rollers and tires. You will get a lot of black dirt and stuff off after cleaning really well try, if it works for a while then yhat was your problem,if it is only temporary then tires will need replacing.
Posted on Nov 08, 2007
SOURCE: paper jam?
I had similar situation, my HP 3650 did not have a paper jam but kept popping up saying it did. After some time checking the paper paths, I eventually went to "Windows Task Manager" then the "Services" tab looked for "Spooler" right clicked it and then selected "Stop Service", wait a few seconds then restarted the "Spooler" tried a Test page print and all is Fine now.
My System is Vista 64 Ultimate.
This would work with any Win XP or NT or Vista OS.
Posted on Sep 27, 2008
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My hp 3940 had a jam. I removed the paper now it
Hello there
i know you have cleared the jam but i would go back and really look closley at the paper path and the internals a small piece off of a paper can cause this to claim it has a jam also if you turn off the printer and use canned air to blow out the whole insides this will help too also clean offf any lenses with a eyeglass cleaner ok ?
best regards mike
Posted on Aug 06, 2009
  • 185 Answers
SOURCE: paper jam on HP C4580 - freed jam but the printer
There seem to be a physical obstruction like a foreig object in the paper pathway.
Try to turn the printer upside down ad shake it.
That is after removing all the paper and securing any movable parts. Don't worry about the ink. they won't fall out.
If you give it a shake you may hear the object rattling.
If you are lucky it will also fall out.
After it fall out keep shaking to see if ther are other objects.
If not you may need to use a small flashlight to examine it.
the common objects are paper clips,
coins buttons and children's krayons. But just about any-ting that is stored above the printer is likely to fall in the paper way.
Goog luck.
Posted on Jan 30, 2010
Printer paper jam
Go To Below official Brother Printer Page For Your problem, How do clear paper jams Brother Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Mar 24, 2014 | Brother DCP 130C All-In-One InkJet Printer
Error 50 of Brother printer DCP-130C
Details of this error code are.
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
Keeps saying paper jam, no paper in it. new come out of box
Don't even try adjust or open the unit. Call the dealer or take it back to him or you will invalidate your warranty and that is not worth it. Let the dealer worry about it.
Feb 23, 2011 | Brother DCP 130C All-In-One InkJet Printer
My printer says that there is paper jam,i already removed the back cover to check if theres paper,but theres nothing into it..i shut it down and on it again and its also again that theres paper jam...how...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 27, 2010 | Brother DCP 130C All-In-One InkJet Printer
Paper Jam Light on still
The print head is jamed too...
some wheel are scaled, there might be also a transparent scled band who help the print head.
If one of those was forced, you can replace the printer.
open it and check also if it's clean, this band might be dirty, cleaning with a wet rug (water) good luck.
Jan 03, 2009 | Brother DCP 130C All-In-One InkJet Printer
Paper jam.. brother dcp 130c
Yes..Buy a real printer and not garbage that Brother sells
Aug 31, 2008 | Brother DCP 130C All-In-One InkJet Printer
Paper jam.help please..
back of the unit has a hinge to open and remove mall paper prts jammed in. if all paper in the front after opening black cover-then pull hard towards you....
Jun 21, 2008 | Brother MFC-3240C All-In-One InkJet...
HP Deskjet D2360 InkJet Printer Logo
Clive
Clive
