TV picture rolls on AV input, but picture fine at RF input
Colour TV ( BPL LVR-20) was working fine until the day it's HT transformer went faulty due to high voltage on power line. I got it repaired and the TV is working fine on RF input but whe i try to connect DVD player or any other device through AV input of the TV set the picture is rolling vericaly (picture slanting /_/ ) audio is ok. the same DVD player worked fine earlier.
hope if someone can help.
  • viveksoy Jan 02, 2009
    colour system is not the problem, non of the settings were changed either on the TV or on the DVD player, this problem started after the power surge, i am trying to find out what component may have gone faulty that is causing this problem.
    anyway thanks for trying
    Problem Solver:
  • 18 Answers
U change the colour system 2 pal
Posted on Dec 26, 2008
My CRT bpl lvr 20 sound OK but not other functions I check the volt optocupler leg 6 volt pls help me
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jan 23, 2016 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
I have just purchased a used Wii system and every thing works fine except that it is in black and white help.
Hi Anne,
It could be due to the wii's current video settings, the previous owner would have had a TV that ran on different viewing options. The black and white picture is caused by having the Wii settings output at PAL 60Hz and the TV input at PAL 50Hz or vice versa (or NTSC). Try going to the wii settings menu and try a couple of different video settings until the colour comes :). If this does not work can you please post what connection you are using for ex. AV or composite.
Regards,
Omeil
Jan 30, 2011 | Nintendo Wii Console
XBox wont work on it? Its hooked to the Av in/output but it wont pick up on channel 3 or 4 I dont have a remote.
To work on channel 3 or 4, you need a RF modulator from AV component input. Otherwise just select the AV input on your TV to use it(Xbox).
Nov 20, 2010 | Symphonic ST420FF 20" TV
When I hook my dvd player up using the red white and yellow cords, the sound will come in but not the video but I have no remote. Please please please help!
The yellow must go to the video and the sound L&R to the audio inputs. If there is no video after selection of the AV, then it is possible that the input video amplifier is faulty. If there is a second AV2 port then use it or else you might need a modulator to connecct vis the RF input.
Other wise the set must be opened to check for failure off the video amp, protection diode at the input.
Sep 21, 2010 | Orion1934 19" TV
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
DIBOSS tv shows no picture
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
Feb 27, 2008 | Televison & Video
Tv. repair
i have bpl fcr deluxe (mod. no. 18cb1) colour tv. i have prob .for search ,auto ,fine option when i go to do this it display TU-LOCK PLZ HELP ME TO FID THE FAULT.
Oct 23, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
