Question about HP Pavilion ze4365us Notebook
RAM upgrade is not working
I have a HP Pavilion ze4300 series laptop. Is G.SKILL 512MB 200-Pin DDR SO-DIMM DDR 400 (PC 3200) Laptop Memory compatible with this computer? The actual model number of the laptop is ze4365us.
    Problem Solver:
  • 13 Answers
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
Posted on Mar 05, 2009
Have 512MB RAM. Was told to max it out because the machine is extremely slow. Has two slots with 256MB. Can I put two 512MB memory modules in those slot to increase 1G or RAM?
yes, after looking up your laptop on hp's website, I have determined the kind of memory you need; (assuming your computer is the one you put in the question, HP Pavilion ze4805us Notebook PC)
you need 2x 512 mb, 200-pin, DDR 266 memory
I looked and found some Corsair (highly respected company in computer memory) memory, for 22.99 for each DIMM (you'll need to buy 2); see link below.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145482&cm_re=ddr_sdram-_-20-145-482-_-Product
If you have any more questions, please let me know!
Thanks,
Mike
May 16, 2010 | HP Pavilion Ze4805us Notebook
How to upgrade memory. I need module definition for 1Gig so I can purchase it.
You need a 512MB PC2700 DDR 333MHz SO-DIMM for a laptop (200-pin). The manufacturer I think doesn't specifically support anything over 512MB. But the RAM is standard and I doubt there is any need to buy it directly from Sharp. The laptop only has one upgradable bay so you may not be able to upgrade past 1.25 GB.
One of the memory covers is not removable, if I remember correctly, that is the one under the keyboard. So the one you update is a panel on the bottom.
Mar 11, 2010 | Sharp Actius AL27 Notebook
How can I upgrade memory from 256MB?
Check any free memory slots available in the laptop and upgrade the same.
Revert back for assistance.
Jan 20, 2010 | IBM ThinkPad R32 2658 Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
What ram can I put in my hp invent 1.4 ghz laptop
The max memory that can be installed in HP pavilion dv4305us is 1024mb and type you require is
512MB 333MHz DDR System Memory (2 Dimm). Paste this into address bar and gives you detailed specs of ur system.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00578143
Oct 26, 2009 | HP Pavilion Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Ram
the ram should not go higher then the MHZ or GHz you have
like 2 Ghz computer should not go over 2gig of ram
i hope this helps out
Jul 15, 2008 | HP Pavilion a422n (DW270A) PC Desktop
HP Pavilion ze4365us Notebook Logo
228 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
