Question about GPX MW-238B MP3 Player
Syncing with Windows Media Player
We cannot sync our GPX238B with Windows Media Player.
WMP keeps giving error message C00D1197 "Windows Media Player cannot find the file. If you are trying to play, burn, or sync an item that is in your library, the item might point to a file that has been moved, renamed, or deleted."
Yet, the GPX player still shows in the upper right window of Windows Media Player. It will not sync or load music.
Any suggestions?
  • 8,596 Answers
Place the music files that you want to transfer into the My Music folder of your computer - Windows will re-read them, and then you can synchronize to your device. Also, make sure the hold/lock switch is not engaged on the mp3 player - it probably isn't, but just check.
-Tha Mp3 Doctor
Posted on Jan 05, 2009
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m230 No Longer Syncs with Windows Media Player 11
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Sep 29, 2009 | SanDisk Sansa m230 MP3 Player
I have a SANSA C250 MP3 player. Trying to sync w/ iTunes.
Put on your ipod and put them on your media player by sync. Itunes can work on the ipod so you use itunes on your ipod and get them.
Apr 06, 2009 | SanDisk Sansa e250 MP3 Player
Sansa Shaker is locking up Windows Media Player
Uninstall all of the Sansa software completely, and see if Windows Media Player behaves normally. If it does not, then uninstall Windows Media Player. Reinstall Windows Media Player first. Then reinstall the Sansa software. Then and only then, plug the Sansa back into the computer. Good luck!
-Tha Mp3 Doctor
Oct 21, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Windows media player not working
Very the file you are trying to play is still there , if it is then create a new play list by allowing WMP to scan your system for playable media. If this fails or the above aint the latter then i'd suggest you uninstall WMP and reinstall it. WMP is in the control panel / add or remove components / Windows Components. You can also log in to microsoft web site and download the latese WMP and install it .
Jul 09, 2008 | Microsoft Windows XP Home Edition
Syncing
It is possible that you do not have Windows Media Player 10 or 11. If you do have WMP 10, then try resetting the GoGear first (with GoGear turned on, find a small paperclip or other such device, and press it into the reset hole; it works when the player turns off). Try syncing again.
If you have WMP 11 or Windows Vista, perform a firmware upgrade:
just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab - this will give your player the firmware upgrade.
If these methods fail, reply to message using FixYa website (not my personal e-mail).
-Tha Mp3 Doctor
Jan 13, 2008 | Philips GOGEAR SA6045 MP3 Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
Windows media player won't allow me to sync files to my My Musix mp3 player....
This player doesn't play well with WMP-11. Try reformatting inside Windows Media Player, but this may not work. Other methods you can try:
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 03, 2007 | MyMusix PD-6030 MP3 Player
Sync
The "please sync" refers to songs that are part of a subscription service, like Rhapsody, or Yahoo Music. If you have one of there, you need to connect to your account and update your license(s). If no, the problem is probably with you own music files. See if the following sounds familiar; - You are using some music from your own Cd's. - You used Windows Media Player to copy the cd's to your computer. - You have not manually changed any of the "default" settings in Windows Media Player. If these apply, by default Windows Media Player "copy protects" your music, giving you the "please sync" error message. To resolve this, you will need to change the "copy protect" option from WMP. Tools>Options>Rip Music, un-check the box for "copy protect". Then delete the songs on your player that are from cd's. Then, re-copy them to your PC. Then, re-transfer them to your device. You can add to this question for more assistance. Best of Luck.
Sep 27, 2007 | SanDisk Sansa m230 MP3 Player
GPX MW-238B  MP3 Player Logo
224 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
