Question about Spinmaster Air Hogs Battling Havoc R/C Helicopters
Helicopter will not run moter is charged switch is on only thing i can thuink odf the switch is not working on the side
  • 30 Answers
The best thing you can do in this situation is to take it back to the store and say it didnt work and get a new and if they dont take it back there is an airhogs number on the box and call that and they will send you a brand new helicopter or you can find the number online at theyre website
Posted on Dec 30, 2008
  • 29 Answers
The moter might be broken
Posted on Dec 25, 2008
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Do the helicopter itself have a on/off switch..tech-one gallant
After fights between teh kids (he's crashing my helicopter) I think I figured it out. The instructions says to select the frequency on the helicopter, but there is no switch. When you first bring up the helicopter and controller, sometimes the green light on the controller blinks a few times. That is it synching up with the helicopter. After you charge the helicopters, turn then both off, Then turn on one helicopter and one controller. The key is when the green light above the one off switch is blinking. I did it with trial and error, so I am not sure exactly how to get it in the mode where it is in pairing mode. RIght now I am reluctant to mess around with it because they are set correctly and the kids are playing with them. I will post later if I figure out the exact sequence for getting them in pairing mode
Dec 26, 2013 | SYMA Toys industrial New Syma S107 Radio...
On what part of the helicopter do i connect the remote charger to, I can't find it?
When the helicopter is sitting upright, locate the on/off power switch located on one side of the helicopter. The charging port is located on the opposite side and will look like a tiny square hole/plug (usually white or beige).
Note: The charging cable can only be plugged in one way, because it's notched / keyed so that it can only be plugged in one way. If it does not seem to be going in smoothly one way, flip it over, and try gently plugging it in again.
Dec 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have a TY 901 medel rc helicopter. it flys, but then suddenly stops, as though it lost radio signal. the battery is fully charged, and the batteries in the remote are new, so i dont understand why it...
u must have change the a b c form thats y it do like that stay on one only. if u r flying helicopter u suddenly switch to b if u do like this then off the helicopter ^& then open it wl work!!
Mar 05, 2011 | Toys
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Purchased Helicopter MINI AIR WOLF Model UJ417. from RiverCenter Mall vendor in San Antonio, Texas 3 days ago, while on vacation...live in kansas.Hope i didn't get scammed. Vendor never said it would only...
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Sep 01, 2010 | Toys
Walkera 37 remote heli
Swap over the two wires that go from the motor to the speed controller. NB. don't swap over the wires at the battery this will destroy the speed controller.
Feb 25, 2009 | Walkera Dragonfly #68 7 Channel 3D...
Spinmaster Air Hogs Battling Havoc R/C Helicopters Logo
121 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Terry
Terry
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
