Question about RCA P56950 56" Rear Projection Television
Rca ctc 195 series
My friend messed with the align#s in 76 4 -18 is there factory settings for the align#s or is there something i can do to reset them to factory settings
  • Anonymous Jan 22, 2008
    1. i mest up the convergence when in software service adjusments and now the portion of the screen that has displays is down to far to read is there a way to reset without being able to see them i have rca ctc 195 series tv
I have rca ctc 195 series tv i mest up the convergence in the software service adjustments and i no longer can see the displays to set them the hole screen is down to far is there enyway to rest it without being able to see the setings
Posted on Jan 22, 2008
    President:
  • 1,284 Answers
Before anyone changes those setings you should write them down.
Posted on Apr 16, 2007
Where is reset button on 35 inch rca tv,I can only view 49
there is no reset button. Ypu need to give more detail about what i sgoing on with your set. Also what is the model and ctc numbers thfey can be found on the back of set. Unplug set for around 30 minnets then plug back in see if it wil work then.
Feb 28, 2009 | RCA 20" TV
Beeps
OK Replace FBT #239111 Flyback transfomer and Hori output NTE2324 (((((((FBT 22.95 -- ACME 1-800-575-9833 1yr warranty on theres.
Dec 28, 2008 | Televison & Video
White noise
Unplug the set for 2 minutes and then trying again.
Jul 31, 2008 | Televison & Video
CTC 195 series
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
Jun 29, 2008 | RCA P56950 56" Rear Projection Television
Rca 52" ctc 195 series, model p52926
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
May 19, 2008 | RCA P52926 52" Rear Projection Television
Ctc 195 sereis tv
Try unplugging your set, If you didnt save the changes this should reset it back to default settings. If that desnt work, you will need to go bak into the service manual and adjust the horizontal size. Just write down anything you change so you can revert back if you have too.
Jan 22, 2008 | RCA P56950 56" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
RCA ctc 195 series
this tv most likely has a shorted horizontal transistor and transformer. Now that you have a heads up on the problem it's best to contact your local tv rep. John
Sep 13, 2007 | RCA P56950 56" Rear Projection Television
Picture flipping
The P52940 uses the 195 series chassis. The vert/hgt control is for vertical height. It adjusts the size of the picture from top to bottom. If your picture is flipping, it most likely means that something is wrong in the vertical circuits. I have seen fluid leak out of one of the CRTs and drip down on the vertical output IC, causeing the picture to go crazy vertically. The set should be serviced by a qualified tech experienced in the RCA 195 chassis.
Aug 18, 2007 | RCA P52940 52" Rear Projection Television
RCA P56950 56" Rear Projection Television Logo
274 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
