Question about Danby DMW773 Microwave Oven
Dandy Designer 800 Watt Microwave
My microwave works but after a few seconds it just shuts off on itself. How can i fix this?
  • Danby Master
  • 9,156 Answers
I would suggest that you try it for a minute or so on the very lowest power level and see if it shuts off. If so, please post again with more detail about how it fails, such as whether it loses all power as if someone unplugged it or just acts as if someone hit the STOP button.
Posted on Apr 16, 2007
SOURCE:
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Microwave runs for a few seconds and stops t
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Oct 23, 2013 | Whirlpool WMH1162XVS Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Need 800 number to call for service
1-888-923-8482 whirlpool customer service phone number for service appointment
Dec 02, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Sensor goes off inside microwave after 10 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 03, 2012 | GE Microwave Ovens
Ive got a d90d25eslr111-b1 micro combi,i poached an egg ani ie exploded in the micro,it blew the electic and went off,if i swith it on its ok,as soon as i shut the door it fuses the electric. why plea
Sep 27, 2012 | Morphy Richards Microwave Ovens
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
SET CLOCK. TRY TO USE. IT SHUTS OFF AFTER A FEW SECONDS.
I found an envelope with troubleshooting info inside the microwave on the left side behind the front vent. A troubleshooting flowchart was included which indicates that this problem is caused by the high voltage capacitor. I got mine out pretty easy and ordered one from appliancepartspros.com for $55 (which includes expedited shipping. I hope this info helps.
Sep 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
Danby DMW773 Microwave Oven Logo
586 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
