In attempting to change cds, after successfully loading 2 cds, after placing the 3rd cd in its slot and closing the tray, the system seemed to jam - not reading the cd. I cannot get the cd tray to open - the system will not respond when I punch the open key.
I tried unpluging the system but that did not work. I continue to get an error message and cannot open the cd tray.I tried unpluging the system but that did not work. I continue to get an error message and cannot open the cd tray.
You can't post conmments that contain an email address.
If message M-Error is displayed it means the disc mechanism is not working. press and hold the stop button then turn the unit off, when you turn it back on if the error persists you will need to get the mechanism repaired.
Powering up the unit and pressing open cd button, tap / slap it gently on its sides. hope cd loading mechanism will be released as it seems stuck in some way.
The assembly which opens and closes is got stuck internally or something is blocking it to open.
just unplug the device for some minutes and then retry opening it it will open.
my friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
Your JVC CD player has some mechanical trouble. It does not load CDs fully into the tray. Either tray loading motor or its belt iis faulty. Replace the belt first and see it helps you. If not replace the loading motro. For both, you have to open and disassemble your CD player. If you are able to do it, and have confidence, proceed. OK
Happy New Year.
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Disconnect the printer from the computer. Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations: -Don't force the CD/DVD tray into the printer. -Make sure your printer is powered on, and the output tray is in the upper position. -Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING: 1. Ensure the printer is powered on. Remove any paper from the sheet feeder. 2. Push in the paper support extension on the printer, and close the paper support. 3. Push in the output tray extensions, but leave the tray open. 4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position. 5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring. 6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide. 7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing: -Burn data/video/images onto CDs or DVDs before attempting to print on them. -Do not use thermal-printable or regular CDs or DVDs in the printer. -Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing. -All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density. -The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo") -Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported. -Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print. -The Epson Print CD software works best with JPG images and may not import some TIFF images.
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
