Question about Brother IntelliFax-2820 Laser Fax
Dell fax machine model 926
Never use my fax machine yet and i do not know how
  • Anonymous Mar 29, 2009
    dell 4 n 1 photo 926. I know how to use the scanner, but have no idea how to use the fax machine
    Genius:
  • 2,120 Answers
RTFM
Posted on Dec 26, 2008
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
All-in-one926 printer fax won't work
get all phone lines and connections checked or replaced also usb connections
Oct 03, 2009 | Dell 926 All-In-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
To use my dell printer all in one for faxing documents
make sure the phone cord is in the line jack on the back of the machine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Dell 926 All-In-One InkJet Printer
Photo 926 fax no dial tone
ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
MY COMPUTER DOESNT RECOGNIZES THE PRINTER DELL PHOTO 926 IT HAS NEW INK
Power off the printer and disconnect the USB (Parallel ?) cable from the printer to the PC. Reconnect the cable. Restart your PC.
If that doesn't work ... go to Start - Printers and Faxes and delete the Dell Photo 926 icon. Then, power off the printer and disconnect the cable from the PC. Power on the PC and log in. Reconnect the cable and see if the printer is found. If so, install the Photo 926 printer driver. If the printer is not found, you have a printer cable or printer hardware problem. Good luck.
Jun 11, 2009 | Dell 926 All-In-One InkJet Printer
Since the time changed my All In One 926 sends the fax exactly one hour after I click send
I would go into the setup on the fax machine itself and look at the configuration. If you cannot fin anything set it back to its default settings.
Mar 12, 2009 | Dell 926 All-In-One InkJet Printer
Fax
Faxing from the 926 is a pretty straight forward process.
Put your document into the document feeder (or if is only one page, put it in the scanner area)
In the menu arrow down to FAX in the menu, enter the number you want to fax to, and push START.
That will scan the document, dial the number and send the fax.
There are additional options for faxing (like delayed fax, and a number of other options which can be found in the owners manual)
Jul 17, 2008 | Dell 926 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
323 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
