Question about Apple iPod touch
I cant connect my itouch to my wireless router
It gives me the password screen, i put the correct one in, and it says it cannot connect.....and i know all the words are spelled corrctally
One of the problems could have been the wireless router's security. if you turn it off you can go on your ipod touch. thats what i did and it worked perfectly!!!!
Posted on Dec 26, 2008
Itouch can't see my network
Not that I am aware of , but you signal strength will degrade if all the devices are on and using at once. Also your ISP MAY "throttle" your service/signal with high data usage. That said, Your iTouch and xBox, in the setting , wireless, the iTouch should see the signal, Is the wireless turned on? It's discoverable? If your wirell has a Password, has a setup box on the iTouch asked for the password? Use the Manuals for the devices to troubleshoot connections.
Dec 26, 2012 | Toshiba WRC 1000 Wireless...
My wifi is working, but I can't logon from my iTouch. It's asking for m wifi password, but don't think I have one. what do I need to do?
You can check if you have an Password set to the Network.
- Connect your Computer using a Ethernet cable to any of the 4 LAN Slots on the Router.
- Open Internet Browser & in the Address Box Type the numbers: 192.168.2.1 & hit Enter.
- In the Setup Page Towards your Left Corner Under Wireless Click Security
- Leave the Password Field Blank & Click Submit.
> If the Security Mode is Set to WPA/WPA2/
- You will Find a Small Obscure PSK Box with an Check Mark Uncheck the Box.
- You will see your Password in Pre shared Key (PSK) Box.
> If the Security Mode is Set to 64 WEP.
- The 10 Characters in Key 1 Box is your Password
- Try Joining the Network on your Itouch using the Password.
--- If you Still cant Get the Network to connect Try Resetting the Router.
Mar 26, 2011 | Belkin Wireless Router
I have a WRT54G -V5 which works great with all my home PC's. Have purchased itouch and it does see my Linksys device and I do know the password but when I put that in itouch it does not connect. The...
You are looking for a Wireless Security key, this is not the Linksys password for the admin portion, look on the bottom it maybe there if not changed. Else goto the router home page and check it there something like 192.168.0.1. or 192.168.1.1 etc etc
Sep 05, 2010 | Linksys WRT54G Wireless-G Broadband Router...
Computer will not connect
I think I have experienced the same problem. ITouch does not have the same wireless security options as the wireless router does. What you need to do is to find what wireless security options the ITouch has and then set the wireless security on the router to an option the ITouch has. The reason it does not save is that it is detecting that there is a problem, it's stupid and thinks it is just the password that is the problem.
Hope that helps. You might get a better answer if you are able to provide better detail as in what wireless security you are using on both devices
Regards
Raph
May 27, 2010 | Linksys Wireless-N WRT150N Router
Cannot get my itouch to connect to linksys wireless router
you have to reset the router then conifugre all of the settings again then give a password that you will remember or you will have to do it all over again or call kinksys and they will reset it for you but it will take a hour of your day
Jan 14, 2010 | Linksys RangePlus WRT100 Wireless Router
Iphone doesn't work with router Dell 1184 broadband router in my house works with windows laptops but not Apple iPhone or iTouch. I have had the router/software installed for 5 years, is there new software...
you said the laptop is connected to the network.
when you try to connect to the wireless network on the i-touch or i-phone, do you see your network.
if your network is secured then you must enter the correct password for the wireless. If you are not sure about the wireless key or the password then you will need to open the router set up page and check the wireless settings.
you can also try to upgrade the firmware ( software) of the router.
Click Here to know more about router and network
Jan 10, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Can't connect iTouch to Verizon GT704WG wireless router
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Itouch wifi connectivity
Go to your computer and type in 192.168.1.1 it should take you to your router's main menu. Then search for something like Wireless Conection or Wireless Config, it should then tell you your roouter's name and password.
Dec 25, 2008 | Apple iPod touch
NetGear DG834GT
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Jan 05, 2008 | NetGear DG834G Router
Apple iPod touch Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
