Question about Yamaha RX-V620 Receiver
Hello, I have Yamaha RX-V620 receiver that I just love...the problem is that I want to run my laptop S-Video output into the S-Video input of the receiver but it will not show up on the TV. I think it is the receiver since when I use problem a friends S-video to RCA cable it works fine. Do you know the possible solution? Thanks, Dale
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
lynchms
  • 93 Answers
SOURCE: yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
  • 133 Answers
SOURCE: connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
Yamaha RX-V620 remote control light stays on
Check that a button isn't jammed. Do all the buttons press normally? maybe the remote needs a really good cleaning to remove the crud from the buttons.
May 02, 2014 | Yamaha RX-V620 Receiver
My receiver will not power on anymore. I think it
It may have a reset button on the rear panel.
Aug 29, 2009 | Yamaha RX-V620 Receiver
Remote control sound buttons not working on rx-v620 yamaha
the remote has a problem.
1. electronic
2.dirt
go to local computer or electronic and get cleaner that is safe for your remote and follow their instructions.make sure you tell them what you want to do. dry air or something.
Aug 15, 2009 | Yamaha RX-V620 Receiver
Even though my dvd and receiver have component video inputs/outputs, when i hook them up i don't get any picture. i have connected the audio with a digital coax and that works fine. why doesn't it work?
Have you enabled the component output on the dvd player and/or switched the output to "component out"? This type of connection doesn't have automatic recognition like scart.
Jul 18, 2009 | Yamaha RX-V620 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Dec 28, 2008 | Yamaha RX-V663 Receiver
Rx-v620 amp remote rav 214
do a google search and buy aa remote i just got one for 40 bucks including shipping
Feb 12, 2008 | Yamaha RX-V620 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
No video when using DVD mode and I don't have a remote!
Why don't you date a guy with at least half a brain, maybe he can help you.
Oct 22, 2007 | Audio Players & Recorders
Yamaha RX-V620 Receiver Logo
128 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
