Question about Samsung L200 Digital Camera
Shutter stuck and camera buzzing
I replaced the memory card while the camera was on, then the camera wouldn't display anything on the screen, the shutter stuck at half-open and the camera wouldn't turn off. Now the camera just buzzes or beeps three times when I push any of the buttons.
What do I do? I bought the camera only 33 days ago.
    Scholar:
  • 95 Answers
I'd pop the battery out and leave it out for about a minute. This gives the camera enough time to clear its memory buffer and such. Make sure the battery is fully powered up and then reinstall. Hopefully that will help
Posted on Dec 29, 2008
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
The screen is black, i cannot see anything on the
First thing to check is to make sure that you didn't just accidentally press the DISP or DISPLAY button on the back of your camera, manually turning the screen off. Press the DISP button once with the camera turned on. If that didn't correct the problem, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 10, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
No image when taking a picture with Canon Powershot SD1000
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot SD1000 Digital Camera
My A540 clicks like it takes a picture but nothing shows on the display screen. When I take the memory card out and insert to computer the frame of pictures show but the photos are black.
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON).
Nov 10, 2009 | Canon PowerShot A540 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Canon SD1000 shows black screen when trying to take a picture
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
Samsung L200 Digital Camera Logo
137 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
