Question about Sony KP-46WT510 46" Rear Projection HDTV
KP-46WT510 Sony, locating boards?
Have been researching convergence IC replacement and feel confident about performing the operation. My ? is, from all my reading the ICs and pico fuses will be located on boards D and G, will that ever be different? In my reading board D should be the large board center left bottom when looking from rear, my board is labled F, and the postings I read said G would typicaly be vertical and to the left of D, which appears to be the power supply to me. I think can handle the componet checks and replacement just can't locate boards visualy at this point. Any help or drawings/pictures would be most appreciated.
Thanks
I have the same model tv, with the same problem... convergence ICs were shot.  As you look into the back of the tv, the ICs are located on the backside of the large heat sinks on the tan board.  The pico fuses are directly under the heat sinks.
Removing the board is fairly easy with the exception of removing the red cables at the rear left side of the board.  You have to exert a lot of force to pull them out (they go into the grey tower looking thing) but they do come out.
I recommend taking pictures of the board before removing, and then make sure you label each connector you pull off the board.  There are six screws to remove as well.
Check with Sonny and Barry at this site.  They gave excellent directions and have a convergence repair kit for your model tv. http://servicemanuals.vstore.ca/index.php/cName/convergence-repair-kits
Posted on Jan 04, 2009
  • telecomguy Jan 04, 2009
    Correction.  Sonny and Ervin Berry
    Just to be sure, I checked mine and my board is labeled F as well.  You have the right one.
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony tv model # KP-46WT510 is showing a three D Picture with a red outline
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 17, 2009 | Sony Televison & Video
Where is the convergence chip located
Convergence out ICsare located on D Board of Sony KP-46WT510
These are 2 big ICs of black color mounted on silver heat sink.
Check out location of D board in TV in below exploded view...
Aug 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence issues
The full downloadable service manual located Here! will have a list of all parts.
Below are a few remedies for convergence:
Subject
Poor convergence, IC8002
Symptoms / Customer Description
Customer hear a popping noise.
[Primary Symptom Code: 1436 ]
Solution
Found IC8002, IC8003, and fuse PS8006 defective on the D Board.
If you need repair assistance, go HERE!
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Finding the convergence ic's
They are located on the D board attached to large aluminum heatsinks They have the numbers STK392-560 you will need to replace both of them. You can get new ones at this link and they will give you free installation instructions with free tech support to help you with doing the repair. here is the link.
Apr 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Kp-46wt510
you need to replace both convergence ICs they are easy to install. You need two STK392-560 ICs you can get them at the following link and they provide free installation instructions as well as free online messaging with a repair tech while youre donig the repair. It takes about 45 minutes to do the repair and you will save about 400.00 by doing it yourself. Heres the link I am one of thier repair/support techs. This is a very easy repair.
just click on the convergence IC catagory and you will see the STK numbers that you need.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem
you will need to replace the stk ic's they are mounted to 2 large heat sinks in side the tv. the ic numbers are on the chips themselves. i do believe it is stk392-510 for sony. once you have the number you can buy these anywhere online. just put new ones in and should be good to go. if this doesnt work then there are a few resistors and fuses by the ic's that sometimes fail.
Oct 11, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
