Question about Samsung SyncMaster 700 L Monitor
Monitor doesn't work
When I start my computer and monitor (syncmaster 701n) i see a green light switchin on and off, and it doesnt stop. The screen stays black. What does that mean?
    Genius:
  • 2,120 Answers
If it is an LCD monitor, the backlight fluorescent bulb is burned out.
Posted on Dec 25, 2008
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
My monitor didnt work at all the green led too
changing the powersystem on the monitor board fix it
Feb 13, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 700 L Monitor Logo
128 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
