Question about Jura Capresso C1000 Espresso & Coffee Maker
Capresso C3000 "FILL SYSTEM" appeared while tryint to decalcify..
While attempting to decalcify my C3000 for the first time today, everything went according to the manual until right after I was to "FILL WATER". I filled the tank (after the durgol/water mixure had been used up, appropriately) then opened the tap and pushed the calc button (as instructed). But then instead of the machine pumping the water from the tank through the steam nozzle and tea spout, it started beeping and said "FILL SYSTEM" and "PRESS STEAM". I have no idea what system it wants me to fill. The water tank is full. And when I press the steam button, it just makes a noise for a few seconds and then starts beeping again, with the same "FILL SYSTEM" and "PRESS STEAM" message. Now it won't do anything. It will only allow me to press the steam button, no other buttons are active. I can't make coffee, can't complete the decalcifying process, and I'm scared it's broken.
  • Anonymous Mar 28, 2009
    My C3000 is doing the exact same thing. Any solutions???
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
SOURCE: Decalcify
decalcify is the same as descale. i discovered the same thing - i believe they've updated the firmware in the machine and not updated the manuals. when you go to purchase the cleaning agent, it's actually called "decalcifying solution". hope that helps. cheers, wizdude.
Posted on Aug 12, 2007
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
SOURCE: screen says decalcify - Gaggia Syncrony digital
Fill watertank with descaler solution, place a large bowl underneath the steam wand, locate the button that looks like a sideways 8 or oo or similar, press it for five seconds and the machine will begin auto descaling. Follow further instructions on scree.
Posted on Apr 15, 2009
  • 81 Answers
SOURCE: keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Posted on Jul 13, 2010
Empty Tray
Hi all, I have the exactly same problem on my Gaggenau CM470 however the drip tray is clean and the contacts in the back is also 100% clean.. I wonder if its possible to disable the sensor/switch on a CM470 ?
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
How to remove the back panel of a c3000
No, your damn right, theres no tool on the market for tohse screws.
I did it with a fine end point pliers, it cause litle damage to the screws head, but worked.
Feb 28, 2010 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Declcification Program not working
Call Capresso co. at 1-800-220-5701. I had a problem and I received excellent help, a step by step walk -through which got my machine back to service. Great machine! Great help!
Jan 09, 2009 | Jura Capresso C1000 Espresso & Coffee...
I have a capresso c3000 and one day it just wont turn on anymore. any suggestions?
We had the same problem. We unplugged the unit from the wall and then plugged it back in again. For us, it was as simple as that.
Jan 08, 2009 | Jura Capresso C3000 Espresso & Coffee...
May 12, 2007 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso C1000 Espresso & Coffee Maker Logo
239 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
