Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have a NX100. Christmas present. (Ho Ho Ho) The Power button, paper button, and ink button are all flashing. I have put paper in. I have held the stop button for as long as 6 seconds, but the ink carriage will not move over to allow me to insert the ink cartridges. I have unplug it, and shut it off. Running out of ideas!!
    Scholar:
  • 83 Answers
***hi there,ill be willing to help you on that. ****
if all lights are flashing, there is a great possibility that the printer is having an internal error. try the ff. steps, turn the printer off, unplug it from the power outlet, lift the whole scanner, check for any obtruction inside the printer, take it out, if none, thats good. plug it to the power source again, trun it on, if same issue persists, that means, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Posted on Feb 17, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
When I turn my epson stylus nx100 on the power button won't stop flashing and the cartiridge holder doesn't move.
Here are the error codes for your Epson model.
Check them and define the problem according to the situation you got.
Mar 22, 2011 | Epson Stylus NX100 InkJet Printer
Red light flasing and printer wont print
Remove all the Cables keep pressing the power button. this is easy way to remove all the power from the printer. Make sure there is no Paper jam and roller is clean to your best extent.( Dont try to be smart her ). Remove the ink toners. reseat the cables. Connect to Computer. Power on teh Computer First. Now poer on the Printer.
Let it ask for the Ink Cardridge. It shall come to Normal behaviour and PRINT. Let me know if you need explainations. I will check the comments. make sure you rate this solution. to get in touch.
Happy Printing.
Sep 12, 2010 | Epson Stylus NX100 InkJet Printer
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
I have nx100 printer just change ink computor and
check the usb cable, or plug and unplug it and see if that does the trick, if you are using a ciss, take the cartridges out for a minute then put them back in, or try unplugging the printer from the wall outlet for a few minutes and plug it back
Nov 01, 2009 | Epson Stylus NX100 InkJet Printer
Computer says black ink is low. Ink light is flashing on Epson Stylus NX100. When I hit stop button to begin replacement it wont move cartridge
2. Open the scanner and prop it up with its support.
3. Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
4. Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the Stop button again to see if more cartridges are expended.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9. Insert the new cartridge into the holder and push it down until it clicks into place
11. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
If the ink light flashes, press the Stop button and press down all the cartridges securely.
Jul 13, 2009 | Epson Stylus NX100 InkJet Printer
Printer not printing, enough ink and paper present!
clean the printer . go to printer properties in the maintenance then click the clean printer head
Mar 15, 2009 | HP DeskJet F380 All-In-One Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
97 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
