Question about Marantz SR-5000
Marantz sr7200 sound cuts out after 5minutes,not completely, just sporadically. No excessive heat or anything- Is there a fix for this? I have a Marantz SR 5000 with a similar problem. The sounds cuts off for a few seconds or a few minutes.I can not seem to find a pattern or a fix!
    New Friend:
  • 4 Answers
Most likley, if I'm right, you have heard some staitcy, crackly noises, accompanied with this failure. If so, the problem is without a doubt on the D.S.P. board, witch is the one with the optical jacks on it, The culprits would then be I.C. 719 & I.C. 720. This is a common problem with this model, and the sr6200 & 5200 as well. A low tech method to confirm this is to touch IC 720 (the smaller one) while it's on. If you can keep your fingertip on it for at least ten seconds, it's ok, and the problem is elsewhere. If not, (IT WILL BE VERY HOT) the the board must be removed (27 screws from left to right) and replace BOTH IC719 & IC720.
Posted on May 27, 2009
  • ivandamme
    ivandamme Jan 09, 2012
    I have the same problem whith a sr6200 and I have tried this test you explain. In my case the IC720 has a normal temperature, but the IC719 really burns!. You can't keep your finger on it for more than a second, so I guess I have to replace both also, don't I?
    Thank you very much.
Any Clue where I can buy these parts online?
Posted on Apr 23, 2010
I have a marantaz sr7200 and all the audio outputs have quit working. What might be the problem?
Sounds to me like something fried. If no output are working, but the rest seems to be. Are you talking like digital audio out, or speaker terminals. Could be an internal relay. or single audio plugin board. Not sure how it's set up on the inside.
Oct 19, 2012 | Marantz SR-7200 Receiver
Marantz 4400 Distortion and scope adjustment issues.
The unit will need servicing, I would not recommend you poking around with the scope circuity as there is up to 580v there and it will ring your bell. I have worked on several 4400's and nursed them back to good health.
www.back2lifeelectronics.com
Dec 11, 2011 | Marantz Audio Players & Recorders
I have a marantz sr7200 receiver and i am unable to get sound when its in DSS mode. The sound works in dvd and tuner modes.
In the setup menu, did you set up the input assignments for DSS to be the correct digital input or analog?
Feb 25, 2011 | Marantz Audio Players & Recorders
Osd won't come on screen
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7200-Receivers-manual/id/511dj782/t/2/
Simply run a composite video (RCA) cable to the TV.
Feb 21, 2011 | Marantz SR-7200 Receiver
I have a Marantz SR7200. I have been using for a long time with 6ch stereo with no problem. Suddenly, it starts to make a lot of noise on front speakers in any mode. It just stops this noise when source...
Hello Sergio.
Sounds like a bare wire (speaker wire) most probably is touching your SR's metal body.
Remove all speaker cables, re-terminate them clean (cut, trim, and twist again) and then re-plug them in to the binding posts.
When you go puredirect, it overcoms some filtering circuits of the board and this should be the reason why it stops.
Try that & advise.
Dec 13, 2010 | Marantz SR-7200 Receiver
Marantz sr7200
most likely the audio pre amp & volume control chip
Sep 27, 2008 | Marantz SR-7200 Receiver
Marantz support question
This is the problem with computerized stereo's. The old analog stuff we could fix forever, but many of these digital problems, only the maker has the tools to repair. Feel fortunate that yours will even offer you support, even though expensive.
Good luck.
Jan 28, 2008 | Marantz SR-7200 Receiver
Marantz SR-5000 Logo
742 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
