Question about Braun 360° Complete 8985 Electric Shaver
Cleaning process stays on INTENSIVE
About a week ago, in the cleaning process, with sufficient liquid, the process locks on INTENSIVE and the light continues to flash. The process will not move forward.
I have reported this and have a case number, but I must drive some 30 miles each way to the repair facility in St. Petersburg.
How to use the self clean feature for a Frigidaire FES 355 ASF
Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
Battery wont stay charged
Its got a drain somewhere can you find the sound?
Nov 26, 2013 | 1993 Subaru Loyale
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
The red cartridge light is blinking on my dock. What does this mean? A while ago, the dock fell over and all the cleaner liquid fell out, so maybe I just need a replacement for the cleaner liquid. If so,...
Re the light:
When the «cartridge» light starts flashing, the remaining fluid in the cartridge is sufficient for approximately 5 more cleaning cycles. After these 5 cycles, the cleaning performance will be reduced and the cartridge has to be replaced.
When the «cartridge» light illuminates constantly, the cleaning function is locked and a new cartridge has to be installed.
Only then, the next cleaning cycle can be started.
To find a replacement, Refer to http://braun.com/ to find the website for your country.
Otherwise, refer to http://braun.com/us/consumer-service.html which will help you locate a local Service Center.
Mode number for the cartridge is CCR2
May 26, 2010 | Braun Syncro 7680 Electric Shaver
My DVD player keeps saying "bad disc" now when just a week ago it was ok! Is there a way to clean it?
Use the CD/DVD cleaner CD with fine bristles which can be used dry or with some cleaning fluid which in turn will clean the optical lens. Do 2 runs, 1 dry 2 with the liquid and try to play it.......sodeep
Sep 27, 2009 | Televison & Video
On my Oldsmobile Alero 2002, all the warning lights are on
You have probably clipped the data line for the computer. This is not a fix!! Just putting bandages where stitches belong!! Any questions just shoot back
Mar 24, 2009 | 2004 Oldsmobile Alero
Washer locked
does it still have water in it? if yes, then you must clean the pump out.
Nov 18, 2008 | Washing Machines
My low detergent light is on while my wife uses tablets when she runs the dishwasher. I tried turning the power off to reset but it still stays on.
The low detergent light comes on because the dishwasher recognizes the powder or liquid wash detergent.
In the Tablet form the dishwasher things you do not have enough becasue the tablets are condensed tightly. I use the tablets and I ignore the low detergent light entirely. The tablet is good for ONE wash and is sufficient.
If your dishes are not coming clean, I recommend that you prewash or scrape dishes ahead of time.
May 24, 2008 | GE Dishwashers
Braun 360° Complete 8985 Electric Shaver Logo
41 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
