Question about Sanyo DS24205 24" TV
For Sanyo ds24205 - screen is black with bright white line, no cable signal or nothing. Can you help me?
  • mommyjoy Feb 24, 2009
    Tv was working fine. Unplugged for while. When plugged back in, can only get black screen whth white horizontal line across center of tv. Only 1 year old!
For Sanyo general problem. No HV, horizontal output transistor always busted, have already check
the surrounding components. pls help me solve the problem.
Posted on Dec 25, 2008
What do I need to do to hook up cable to this tv?
This TV has the following inputs:
RF input, composite video/audio input
The easiest would be to use coax cable
Aug 11, 2017 | Sanyo DS24205 24" TV
My Sanya flat screen TV,has 3 different colored bright lines running from top to bottom in the middle of the tv.What is wrong, and can I fix it myself.
This is not a do at home repair and it will likely cost more than cost of a new TV to have a repair shop fix it.
May 18, 2012 | Sanyo DS24205 24" TV
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Black screen with a horizontal white line across the middle.
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Sanyo DS24205 24" TV
Gray screen with horizontal lines accross it
sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Mar 01, 2009 | Sanyo DS32224 TV
Sanyo DS24205 24'' TV Not Recieving Signals.
Ok, cable connected is good. Can you move tv to another connection or run another cable from a working source. Maybe go into setup of tv and check input.
Nov 17, 2008 | Sanyo DS24205 24" TV
Sanyo Model DS24205 television
On the website it states that ur telly uses the NTSC format standard, this is an based on a analogue system
Buy a set top box.
Cheers
Jul 21, 2008 | Sanyo DS24205 24" TV
Sanyo ds24205
I don't have any specific information on this model.... but I can tell you that the problem is the vertical deflection IC or just the solder connections on the PC side of the IC. The part number usually starts with the letters LA and then 4 numbers. Will be on a metal heat sink. And sometimes there is a 1ohm resistor that opens and even the diode may be bad in that circuit coming off of the HV transformer through the resistor and then the diode then to the vertical IC Hope this helps.
Mar 16, 2008 | Sanyo DS24205 24" TV
TV got sound but only shows a complete white screen and the message no signal connection
call a tech your tv needs to be repaired tv is having a problem in the video circuit ther is a cip that controls that circiut checks should also be made in the related circuit.video IF circuit.good luck
Mar 01, 2007 | Sanyo DS24205 24" TV
Sanyo DS24205 24" TV Logo
117 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
