Question about Magic Chef CER3540 Electric Kitchen Range
Oven won't heat past 240 degrees-F7 kept flashing prior to issue.
  • wesley_pinkh Dec 25, 2008
    The top coil is working fine, but the bottom coil won't heat at all
    President:
  • 373 Answers
Function key shorted or stuck
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Posted on Dec 25, 2008
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
The oven will only heat to about 240 degrees. It's very slow to preheat and doesn't seem to get above 240 degrees in about 45 minutes.
The most likely cause is the bake element. The floor of the oven is removable exposing the element (74008693) It will likely be visibly broken.
Jan 13, 2011 | Maytag MER5775Q Electric Kitchen Range
Max 160 degrees celcius
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Lofra MXD96MFEPI Dual Fuel (Electric and...
JGBP90MEB1BC _ The oven will not heat above 300
if you have 240 volts at the range, then its your element, its got a "hot spot" in it and will be pitted and discolored in the area and is ready to break you can see it if you move it it will probably separate,new element time
Jul 17, 2009 | Ovens
GE wall oven
Hi Den3,
Are you sure that you have not inadvertently switched to the Celsius temperature mode? A temperature of 282 degrees C corresponds to 540 degrees F.
I doubt that it is the heating element. They either fail by short circuiting or by opening up completely.
Regards,
Powerman
Sep 15, 2008 | Ovens
Magic Chef CER3540 Electric Kitchen Range Logo
98 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
