Question about Canon PIXMA MP130 All-In-One InkJet Printer
Put in cartridge error
Can you help?
    Problem Solver:
  • 37 Answers
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and tPut in cartridge error - mp130_scanunitclosed.gifbr />mp130_scanunitclosed.gif
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCDPut in cartridge error - sj402033.jpgmessage asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Posted on Jan 14, 2009
How to fix Error 5200
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
First of all unplug the printe
r then open the top and bring the ink cartridge holder to the middle and now raise the gray bar and remove the print head assembly with the cartridges in it. After it lower the gray bar with the head missing and close the top with the head out. Now restore the power and wait till the printer starts.It will tell you to put in the cartridges, Put in the cartridge and restore the print head, close the top and the printer will resume working and Error will be removed.
I hope this solution helps you
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Nov 15, 2011 | Canon MP490 InkJet Printer
10.92 errror message. I have install a new black cartridge but the message keep telling me to close the door. HELP PLEASE. THAQNKSw
10.92.XX says that the print cartridge XX(00=black, 01=cyan, 02=magenta, 03=yellow) is not engaged correctly.
Since the error occurred after replacing the black cartridge, it's a good bet that the black is bad.
Put the old black in the printer and see if the error goes away.
Open and close the front door slowly and look at the cartridges. You should see the cartridge flaps all open and close as you open and close the front door.
If the flaps don't all open and close, the cartridge lock mechanism could be broken.
You can run the DISABLE CARTRIDGE CHECK diagnostic. This will allow you to remove all the cartridges and install all or one in any slot you want. In your case remove them all and put the cyan in the black slot and see if the error goes away. If yes, put the black in any empty slot. If the error returns, the black is definitely bad.
Apr 18, 2011 | HP LaserJet 3600n Printer
I have problem. Message on the display "cartridge error. Refer to device documentation to troubleshoot" what do i do?
First take out one and close the door. Take note of the error that comes up. Then put it back and take the other cartridge out. Take note of the error now. One error will be Cartridge Error and the other will be just letting you know that you need to put a cartridge back in. The cartridge that was in while you got the Cartridge Error is the bad cartridge. Replace and go!
Mar 30, 2011 | HP Officejet 5610 All-In-One InkJet...
I replaced the magenta cartridge with a cartridge from cartridge world. I keep getting an error message that says "10.10.02 supply memory error." What do a i do. I already took all the cartridges out and...
This is usually caused by a third party toner and not an hp toner cartridge. My suggestion would be to see if you can get an oem hp toner cartridge (magenta) and see if the error goes away. If the error goes away then you know its the toner cartridge. This happens because all the manufactures put a chip into the cartridge that make it so you have to kinda use there toner. When third partys manufacture cartridges sometimes there chip they use is not compatible with your printer. Another way to test this would be to put your old one back in. You will still get toner empty but at least the 10.10.02 should go away.
I hope this helps please let me know how it works out. thanks
Apr 21, 2010 | HP LaserJet 3600n Printer
I put a cheaper replacement cartridge in for the printer and it says on the printer Error#1203. It also says cartridge error
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
Hope this helps
Mar 23, 2010 | Lexmark All-in-One Printer with PictBridge
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Printer error message ''Cartridge error''
just check the no. of the cartrige & is it org. or compatiabe
Nov 14, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Merroy error 100.10.10
There isn't a known error of 100.10.10 on an HP2600n. The is an extremely rare 101.000 which is color plane registration but I'm guessing your not getting that.
I'm assuming your actually having one of the following:
10.0000, 10.0001, 10.0002, or 10.0003
10.1000, 10.1001, 10.1002, or 10.1003
These are supply errors (toner cartridge). The toner cartridges have a smart chip on them and if it's not reading correctly you can get one of the errors I mentioned above in the "10" errors. In that case look at the last number in the string to isolate it. "0"=Black, "1"'Cyan, "2" =Magenta, "3" = Yellow. Simply replace the identified cartridge.
We have seen a lot of refilled or self refilled cartridges that the supplier or user didn't put a new smart replacement chip on the cartridge, pulled the chip without replacing or actually put the wrong one on the cartridge. This would cause the "10" errors. In some rare cases a surge in power can knock out a chip on the cartridge.
Here's a photo of the chip on the black cartridge to help you locate it.
If you are getting a "10" error identify the last number to identify the color and replace the cartridge.
If you are ACTUALLY GETTING AN ERROR 100.10.10, contact HP as it is an undocumented error and likely only HP may be able to resolve it. I have even researched the error through Canon (they make they base machine for HP) and Canon has no record of this error either.
I hope this helps you. If so hit it with a FIXYA. Thanks.
Aug 28, 2008 | HP Color LaserJet 2600n Printer
"Put in cartridge" error message
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
252 people viewed this question
old marine
old marine
