Question about SanDisk Sansa Fuze MP3 Player
Sandisk sansa fuze in foreign language need to change to english
Need to change to english from foreign language
  • cybernette20 Jan 05, 2009
    can't change it back to english because I can't read the menu in the foreign language. help please!!!
  • Anonymous Mar 12, 2014
    My Sansa Fuze has been working fine for a year. All of a sudden, it changed the order of the songs to alphabetical in the folders. How can i change it back to track order?
  • 14 Answers
Turn on your sansa fuze then press the menu button then go to the picture of settings then go to the very bottom of the list and press the center button then go down 5 slots and at the very top it should say english and press that one or find someone that speaks the language and have him or her fix it
Posted on Feb 20, 2009
I need a player where i change foreign language in english...... please if know about that type of player or software please tell the name of it.........
Posted on Jul 27, 2010
Go to settings (on home screen) select it and then find language and change.
Posted on Dec 26, 2008
HOW DO YOU CHANGE THE LANGUAGE ON SANSA FUZE
I assume your current language setting is 'English,' and you want another language;
1) Press the top menu button, and roll the wheel clockwise or counterclockwise to get to SETTINGS
2)Click RIGHT side of wheel to get to Settings submenu.
3) Roll the wheel to SYSTEM SETTINGS at the bottom of the submenu list.
4) Click RIGHT side of wheel.
5) Roll the wheel to the sixth menu entry, LANGUAGE.
6) Roll the wheel to select from the 31 available languages;
7) Click RIGHT side of wheel to select the language.
What if you clicked the wrong language and are now stuck in Chinese (which you don't read)?
1) Press the top menu button. Rotate wheel to the picture of the 4-level 'Mixer'. This is SETTINGS
2) Click RIGHT.
3) Rotate clockwise to bottom of submenu list.
4) Click RIGHT.
5 Rotate clockwise to the SIXTH entry from the top.
6) Click RIGHT.
7) Rotate COUNTERCLOCKWISE to the top of the list.
8) Click RIGHT.
You should now be in the default English menu.
One other suggestion;
Download the PDF Manual for the SANSA FUZE, here:
kb.sandisk.com/app/answers/detail/a_id/142
Note; It's in English :-)
Sep 28, 2011 | SanDisk Sansa Fuse MP3 Player
I set up foreign language taht i cant understnd , hw can i cahnge it to english?
Press the Menu button. Select the four vertical sliders. Select the sixth item on the menu. Select the sixth item on the submenu. Select "English."
Sep 10, 2011 | SanDisk Sansa Fuze MP3 Player
I just purchased a Sandisk sonsa fuze+ I tried to have everything in English, however, there seems to be different languages on the screen along with English language. Is this normal and if it is not, how...
When you go in to the settings menu and set language to english it is needed to save this changes.
When you are finished personalizing your settings, press and hold the Back button to return to the main menu. Your changes will be saved automatically.
If your problem persist you could make a reset Factory Settings.
This will restore the player to its original factory settings.
1. Select Restore.
2. Use touch-pad to highlight Yes then press the Select button.
I hope your player will work fine again.
Thanks.
gylacz
May 15, 2011 | SanDisk Sansa Fuze MP3 Player
Hi, Just charged this item, MP3,(SanDisk Sansa Fuse+ 4GB), for my daughter, now it is in a strange" Re'gion", how do I get back to English...?
From main menu, select settings.
Then select "system settings"
Then select "language"
Use thumbwheel to select English, then hit select to select it.
The online manual is here: http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
If you cant read the current language, translate the words by typing them into google translate.
Feb 28, 2011 | Audio Players & Recorders
Language is not English. How do I change the
You must be able to either follow the manual and go in timing to the language menuto shift over to english. Other wise if you are familiar with the language on the screen, then open menu- open language settings- set to English. Helpful? Good day
Jul 02, 2010 | SanDisk Sansa Fuze MP3 Player
How to reset Sansa Fuze volume levels too low!
settings > System Settings > Reset Factory Settings > Yes
Language : English
Region : Rest of World
settings > System Settings > Volume > High
Mar 22, 2010 | SanDisk Sansa Fuze MP3 Player
Scandisk language change
On the main menu go to Settings then to System Settings. Scroll down to Language and set desired.
Jul 14, 2009 | SanDisk Sansa Fuze MP3 Player
Foreign language on player, cannot install firmware update.
I was able to locate a tutorial on the Sandisk knowledge database that allowed me to reset the unit back to English.
Thank you.
Feb 12, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
2,337 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
