Question about George Foreman GGR62 Grill
Broken piece connecting timer and thermostat
The black, plastic piece that connects the timer shaft to the thermostat is broken (underneath the hood assembly). When fully assembled, the shaft doesn't fit into the broken piece to set timer and thermostat. I just need to know how I can get a new piece. Thank you.
  • Anonymous Feb 23, 2009
    What is with the George Foreman Appliances?...They sell the grill as an
    indestructible, lifetime appliance that will never need any replacement
    parts! When you go to their site they even tell you that they do not
    offer any parts for their products.. Searching the net is a waste of
    time since nobody can offer any parts either! Lose a part for your
    $100.00 grill and just toss it out and buy another! Go Figure!
  • 944 Answers
These are the guys you need to speak to; http://www.esalton.com/control/contactus 1-800-233-9054 Hope this helps - please ask again if you get no luck from them :)
Posted on Apr 15, 2007
SOURCE:
How do i open the hood on a 1998 chev silverado if release cable is broken
The best way is to reach up from underneath and pull the lever that the cable is connected to while someone pushes down on the hood. This should release it. I've seen some ppl bust a piece of the plastic grill to get to it, but there is no need. Good luck
Oct 04, 2014 | 1998 Chevrolet Chevrolet silverado
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
My 93 saab 900s only has third and fourth gears.
I know exactly what happened. Look at the shifter linkage at the transmission. It's under the hood, close to the firewall, directly forward of the shifter knob. There's a black plastic bushing or connecting piece which broke and became separated from a 5-6mm diameter steel rod. You will see it clearly if you look under the hood while someone else moves the shifter knob around from inside the car. Buy a small metal hose clamp (~1 inch diameter or less, coolant hose clamp, same size as the clamp on the coolant reservoir). Slide it over the steel rod, push the rod back into the broken plastic piece firmly, and slide the clamp over the broken plastic part, and tighten it up. You should have all 5 gears back. It happened to my 1997 900SE, and this improvised repair has been holding up fine for two years now. Good Luck.
Masa
Aug 28, 2012 | Saab 900 Cars & Trucks
91bmw 3181 coolant drained. Connection fr rad to motor appears to have broken at motor. Not enough to connect back up. Piece on motor too short. Is it much work to replace the piece on the motor
At the motor? That is odd. Is the part plastic? BMW currently sells a metal thermostat cover for this car. The 6-cyl BMWs used a plastic thermostat cover which failed routinely.
The BMW thermostat cover should cost you about $50 at the dealer or $40 on line. Gasket is sold separately. You will want to replace the thermostat while you have the thermostat cover off.
Jul 30, 2011 | BMW 318 Cars & Trucks
Washer will not begin spin cycle
Hello,It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor.
Thanks
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
WONT WASH OR SPIN
Put motor and pump back together and plug in motor. You should be good to go.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Jan 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Nelson traveling sprinkler broken plastic part
I just took mine apart about a week ago. If, I recall correctly, you broke the T piece. That black plastic or nylon nut that is still connected to the transmission should thread off fairly easily.
I expect you can buy the part from Nelson.
If, solution #1 is correct and you find you cannot get the part, I've done some truly amazing repairs with that epoxy product called PC7. Depending how much of the part is broken and or missing, you might find a combination of what you have plus a brass T fitting plus the PC 7 will get it working.
You have nothing to loose.
Jul 16, 2009 | Nelson Sprinkler: Traveling Tractor
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
George Foreman GGR62 Grill Logo
181 people viewed this question
Top George Foreman Grilling Experts
Jaime Hernandez
Marvin
Marvin
Fahr Quad
Are you a George Foreman Grilling Expert? Answer questions, earn points and help others
