Question about Electrical Supplies
Quit generating power
It was running and lights were working - but then the lights went out. Is there a reset or breaker somewhere? Or, is there something else the issue could be>
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
There should be a breaker reset button. It should be by the plugs on the generator.
What kind of generator is this?
Posted on Jun 04, 2009
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
NO 20amp 120v power
you probably tripped a circuit breaker. Carefully push in all the circuit breakers, I bet that one of them will give slightly and power will be restored.
Sometimes the 20amp outlet is also a GFI outlet. You may need to reset the outlet itself if so equipped.
May 21, 2010 | Coleman Powermate Powermate 5000W...
Breaker tripped, wouldn't reset. After about 20 minutes it reset.
YES YOU ARE IN DANGER. DO NOT turn this breaker on again. Please get a registered electrician. There is a risk of fire or even explosion. BE CAREFUL. Have you got a smoke alarm?
Feb 05, 2010 | RTO Circuit Breaker Box For Electrical...
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Coleman Powermate 5000 reset problem
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
Dec 17, 2008 | Coleman Powermate Premium Plus 6250W...
1994 t0yota camry
check external fuse and relay box under hood. "acessiories"
Aug 05, 2008 | 1994 Toyota Camry
Electrical Supplies Logo
97 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
