Question about RCA P52921 52" Rear Projection Television
Rca 52in p52921yx2 need help
Bought this tv for 50.00 the guy said it had a problem when you turn it on the pic looks good then after about 5 to 10 min it bows an the colors seperates red blue green i need help i always wanted a big screen never had the money to get one found this one for my wife for valintines day she was so happy thank you please help
I just had the Same identical problem fixed on my identical tv. The problem is with a trashed circuit on the digital convergience board. Certified electronics is the company i had come out and fix mine, they charged $395.00. Which included replacing the circuit, reconditioning the power supply and cleaning all 3 projector lens and the interior of the cabinet and screen.
Posted on Jun 06, 2007
    Genius:
  • 1,074 Answers
If this problem happens after such aive mins and it is consistently giving that same problem to every time the set is turned on then it is a cold solder in your circuit of the video.if it gives that problem on start up ten the video amp and related circuit should be checked.have a tech check your tv.good luck.
Posted on Apr 16, 2007
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w20 52in. rearprojection tv monitor
Remove the back panel from the tv where the input jacks are located. You will see a red power wire. Just above that and to the right approx. 7" or so you will notice a [_] shaped metal shield surrounding a cgreen/gold capacitor. You may need to remove the plastic cover that is located directly above it about 6-7" in length to gain easy access. Run your finger over the top of the capacitor. If it is beveled rather than smooth you have found a definite solution to your problem. The part number located on the board is CP150 16v 2200uF capacitor. It will look like a tall cylinder. Good luck!!
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
61 in RCA Rear-Project color seperation
Your used TV is not worth much. Let us not fill our land fills with TV's. You may give it to a charitable oranganization (tax deduction) or local school that has an electronic course. Enjoy your new LCD you a great choice in type and brand.
May 04, 2008 | RCA P52926 52" Rear Projection Television
RCA P52921yx2 WIll not power on only clicks
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
Nov 29, 2007 | RCA P52921 52" Rear Projection Television
RCA P52921 52" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
