Question about Denon AVR-1100 Receiver
Denon AVR-1100 receiver "PROTECT" mode
Re: Denon AVR-1100 receiver
Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and the little red light under the "ON/STANDBY" is blinking red. I cannot get the readout to change by pushing any buttons? Seems almost to be frozen. What is "PROTECT" mode and how to I get out of it to start using the reciever again?
  • 2 more comments
  • Anonymous Dec 28, 2008
    i have same problem with avr-1200
  • ajensen Dec 28, 2008
    i have same problem with avr-1200 ,auto lite with protection flashing and no front panel control
  • Anonymous Mar 22, 2009
    there might be a shorted transistor or other component in the output section of this device. you will have to take it to a technician.
  • Anonymous May 14, 2009
    my denon avr-1200 just started doing the same thing yesterday...been fine before that.  manual is long gone and I cant seem to get it out of this funky state.
    Sniper:
  • 99 Answers
Replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Posted on Jul 27, 2010
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
How do you get a denon avr-2000 out of "protect" mode?
How diid i get a denin avr 2000 out off protect mode?
Sep 12, 2010 | Denon Audio Players & Recorders
I have a denon AVR-2000 that has gone into protect mode how do i get this off?
power output short....or spk or spk wire short check and .need service...
Jan 07, 2010 | Denon AVR-2800 Receiver
Control other devices connected to Denon AVR-1100
No you can't use this remote to control other devices unless they are Denon devices. This is not a learning remote
Jan 24, 2009 | Denon AVR-1100 Receiver
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
No power
Unit is in protect mode. Most likely cause of protect activating is blown channel (shorted output transistors). I work for a Authorized Denon repair center in Michigan if Shipping to Michigan is economical let me Know kstahl65@att.net
Feb 06, 2008 | Denon AVR-2802
Says protect
Probably some speaker wires got shorted or the output stages freaked out and the cpu went into protect mode. Normally plugging it out of and in to the wall socket should/could reset it.
First check all wiring at the speaker outputs and on the speakers
then if it still wont startup you could try the avr-1500 method with
some trial and error pressing of buttons.
avr-1500 reset method:
Unplug the unit from the wall, hold down both video select and audio select at the same time, plug it back in. Keep holding both buttons for 2 secs, unit will reboot. As you have no audio select button on your avr-1100 you might try pressing video select and another key to see if this will reboot it.
Jan 13, 2008 | Denon AVR-1100 Receiver
Denon AVR-1100 Receiver Logo
1,172 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
