Question about GE JVM1630 Microwave Oven
Re: Solution #1 Nov 1,2006
I changed the bulbs under the microwave and the circuit breaker for the microwave outlet blew. I was using a pliers to get the bulb base out and must have shorted the circuit. I put new bulbs in and they will not work. Is there an in-line fuse somewhere on the unit that I must replace? You stated that you regularly repair these GE / Samsung boards for this problem for customers from across the country for $32.50. How can I get ahold of you to have this same problem repaired. Please let me know.
  • Terry Westemeier Apr 18, 2007
  • bowmana1127 Mar 19, 2009
    I did the same thing and did not remember to unplug the unit first. I didn"t know whether I could replace the socket lamp itself or the lamp cavity. Does anyone know what I should do?
  • GE Master
  • 9,149 Answers
This rarely blows the internal fuse, but the fuse is located either behind the control panel on the floor of the oven or on the door switch holder. You can send us e-mail via our Web site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Thanks very much.
Posted on Apr 16, 2007
  • William Miller
    William Miller Apr 19, 2007
    * * CONTACT INFORMATION * * *
    You can send us e-mail via our Web site, which is linked at our listing here on FixYa:http://tinyurl.com/yzjozk
Microwave blew house outlet circuit breaker, what is wrong
you have a short it could be anything would need to be diagnosed and dont plug back in and try to use again potential fire hazard --compare replacement cost to repair cost
Sep 09, 2016 | Microwave Ovens
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwvae won't work
Techy, that's where I would start. There is an internal fuse. Sometimes there up front where we can get at them and somestimes we have to drop the whole oven and remove the wrapper. Unplug the microwave and remove the upper grill by removing the two screws holding it on. It will pull off forward. The control panel has 1 screw on top, remove it and lift up and tilt out. See if you can see the fuse cradle and fuse. 20 amp, part number 4358704. The diagram I have shows it more toward the back but these diagrams can be wrong. If you don't see the fuse behind the control panel you probably will have to drop the oven and remove the wrapper. Catriver..post back.
Mar 25, 2007 | Whirlpool MH7130XE Microwave Oven
Bulb and Fan Not Working
The problem is damage to the control circuit board. It wasn't the pliers. This damage happens whenever the lamps are removed or installed without disconnecting the oven from the power line first. We regularly repair these GE / Samsung boards for this problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by a search on Yahoo.com. It's important information to consider before proceeding.
Aug 30, 2006 | GE JVM1630 Microwave Oven
GE JVM1630 Microwave Oven Logo
80 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
