Question about Microsoft Windows XP Home Edition
Error Message at Windows XP start up
I get the following error message on windows XP start-up:
Smart Bridge Alerts: Motive SB.exe-Entry Point Not Found
The procedure entry point GetProcessImageFileNameW
could not be located in the dynamic link library PSAPI.DLL
What is this and how can it be fixed?
  • joybar1935 Mar 14, 2009
    I
    have virgin broadband but the same problem
    Smart Bridge Alert the procedure point entry cannot be found etc
  • 48 Answers
Im assuming you have BT Broadband? If you delete BT Helper or something along those lines from Start -> All Programs -> Startup that should fix your problem.
Posted on Dec 25, 2008
Miregsvr.exe - entry point not found
what PC (HP, model and number)
what OS>? XP? we can never guess the OS you run.!
what version of loadrunner, there are so many (from v1 to V15 ??????)
and not all run on
windows 95 to W10.
sorry, impossible that.
the work around, is use the correct software.
for your unstated PC./OS
If XP and is infected, like all are,
then there is no work around, the fix there is to reinstall
the OS, clean. (AND LR and the APP under test)
or (long ago cured by OS upgrades) this...
Google DLL H3LL, that too is a big problem before VISTA.
Apr 12, 2017 | HEWLETT-PACKARD HP LoadRunner
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
When my pc starts up i get the message :Air GCFG .exe- entry point not found. Then I get a second error message saying Procedure entry point aspInitialize not found in the link library wlanapi.dll
did you update from sp2 to sp3 remove sp3 for one reason
fixed it by going to Windows Defender, Tools - Software Explorer and
disabled AirGCFG.exe from automatically starting at boot.** Now I don't get the error message and
the Dlink NIC card works just fine.
AirGCFG is a NIC monitoring function and the NIC will work without it.
Dlink was advised and reported back that SP3 was still Beta and they may work on the problem after
MS releases the final SP3.
I informed them that they did not know what was what and I would not hold my breath until they fix
the problem.
Found out the problem was due to a new version of the wlanapi.dll file introduced with SP3 that
conflicts with the Dlink monitoring file.
** Note: AirGCFG did not show up in the "msconfig" startup listing. But does show in Windows
Defender, with an explanation of what it does.
Jun 11, 2009 | Microsoft Windows XP Professional With...
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
Cannot access AOL
mimboot.exe is the startup application for Musicmatch Jukebox. It does not need to start with Windows. It looks like you may have deleted or unsuccessfully uninstalled Musicmatch Jukebox. Reinstalling the application should resolve the issue. If you don't want the program after the re-install simply uninstall it again in add/remove programs.
Please note: this can also be a trojan horse. If you haven't already I would suggest running a good anti-virus and anti-spyware program.
Hope this helps
Apr 07, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows message: SOUNDMAN.EXE - Entry Point Not Found
install service pack 3 if that doesnt work then reinstall the OS in repair mode.
Jan 02, 2009 | Microsoft Windows XP Professional With...
Getting a error that my computer can not find motivesb.exe.. How can I fix it?
this file probably came as part of your DSL providers software.
have you changed DSL provider or uninstalled the DSL software?
-click on start > run
type msconfig
press ok
Click on the Startup tab
Look for the entry MotiveSB
Uncheck it if found
click on save
click on close
press restart
after restart check the box that appears and close the window
That should remove its entry from startup.
-You can uninstall the 'Motive smart Bridge' or 'Verizon Online Support Center' if it has an entry in control panel > add/remove programs panel
Jul 06, 2008 | Computers & Internet
Problem when windows XP is starting up. Isass.exe - System Error
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
Jun 17, 2008 | Dell OptiPlex GX280 PC Desktop
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
1)error message upon clicking on an .exe/it says my Msinit.ocx is wrong/more details ff; 2) what program do I need if i wish to open a .ppl thingey
What was the error message, also you are stating only problems, not questions, please be more specific into what you want to do so people can help you.
the only solution I can think of for the OCX error is to re-register it
Go to 'Start' -> 'Run', type (or copy/paste from here) 'regsvr32 C:\Windows\System32\MSINET.OCX' and press Enter (a message box normally appears containing 'DllRegisterServer in C:\Windows\System32\MSINET.OCX succeeded.')
Also you might have to update your .net frameworks (check microsoft update.
I went to the bridge barron site and only found this
http://www.greatgameproducts.com/weeklydeals/dealoftheweek.cfm
please link to the PPL file.
Mar 03, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
174 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
