Question about Denon Televison & Video
Denon dvd player is in progressive scan-need it in interlace
Older denon dvd-3800 player. hit progressive scan in setup by mistake and now cannot see setup to change back to interlace.help Marc
Used single composite video plug to get back to setup.all is good again
Posted on Dec 26, 2008
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
How do I reset this ilo dvdr05
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Dec 07, 2006 | iLO DVDR05 DVD Recorder
Televison & Video Logo
338 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
