Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Power went off for a few minutes.When tv came back on it had no color ,just black and white .We can put a DVD in and it will play in color. Toshiba,Regza Model42HL67US- Chassis TAC0751-Serial NO#AM392032069 Need help!
  • extremedesig Feb 17, 2009
    I have the same problem.
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
  • 360 Answers
SOURCE: The tape only plays back in black and white.
normally this would be a tracking error, if you can manually adjust the tracking, this should fix the prob...if there is no way to manually adj the tracking, use a video head cleaner to see if cleaning the heads will help the auto track to function better.
clarkco
Posted on Feb 09, 2009
SOURCE: DVD only plays in black and white on my Toshiba 27D46 TV
Check on the dvd menu for the video format maybe that´s the problem
Posted on May 16, 2009
  • 47 Answers
SOURCE: Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Posted on Jun 25, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Turned my tv on and for some reason the DVD source is in black and white and controller not workin for it, TVs colour for other outputs and controller works only DVD that doesn't .
If you're using component cabling (red, green, blue cables) a black and white picture will occur when only the green cable is plugged in.
If you're using HDMI cabling, try a different HDMI port and see if your color comes back.
If not, unplug the set from power for a few minutes, plug it back in and see if problem persists.
If you still have the same problem, check the DVD player on another TV. If it shows color on a different TV, then your TV will need a replacement digital board which we can check availability on once we have a specific model number. If it's black and white on a different TV, then you have a problematic DVD player.
Dec 15, 2012 | Televison & Video
The color went out so that now it is black and white. If I turn off the tv for a few minutes it will go back to normal. Then after being on for a few minutes it will change back to black and white. If you...
This is unusual for this model, can you tell me what source you use for signal? Cable? Sat? Direct TV? Also how are you connected----via the coax fitting or the rear AV jacks.
Steve
Nov 01, 2011 | Mitsubishi WS-65809 65" Rear Projection...
White colour displaying as pink on DVD recorder DMR-EX77EB, problem just started a few weeks ago.
Very similar problem with my DMR-EZ27. About 10 minutes into playing back a DVD the color starts going away until I only see a black/white movie. Sometimes color comes back in partially then back to b/w
Feb 13, 2011 | Panasonic DMR-EZ48VK DVD Recorder
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
32F531T color tv loses color after about 15 minutes.
the crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Apr 21, 2008 | RCA 32F531T 32" TV
DVD player in black and white
Ok I know I just made a comment but guess what... heres the solution!!!!!!! I was sooo mad that I went and started playing with the cables and got it working. You have to plug in white to white, yellow to green and red to blue on the back of the DVD player and match up the colors on the back of the tv. And it plays in color!! Hope this works for you too!
Jan 04, 2008 | Disney 13" TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
