Question about Garmin nuvi 260W GPS Receiver
Unit won't remain powered-up
Nuvi 260w just out of box. Unit not connected to external power source, no AC cord provided. Unit turns on for a second then shuts down. I suspect unit's internal battery is low. Is this normal for a new unit just off the shelf? My next move, attempt to charge unit in vehicle. Do you concur and what's normal full charge time requited? Thanks, Jim Parker
  • Garmin Expert
  • 343 Answers
You are absolutely correct Jim. Low Battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Posted on Jan 18, 2010
When i turn the garmin on, it only says garmin on it and it won't go any further
Try doing a soft reset on the nuvi. If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
If the problem cannot be resolved, it may be necessary to return the unit to Garmin to claim for warranty.
Sep 13, 2011 | Garmin nuvi 260W GPS Receiver
My wife's Nuvi 350 will power on, start loading maps, then shut down (stays on for a total of 18 seconds). It's only 2 years old.
If its not connected to an external power source, then your battery is shot.
http://www.sharc.net/gps_battery_repair.htm
Should not do this when connected to an external power souce like the DC car charger or AC wall charger.
- Jim
Sep 07, 2010 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 260W will not start up. When not conneccted to power, unit attempts to start up, shows Garmin logo, then copyright logo, then "loading maps", then goes blank. When connected to power, the unit...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Jan 09, 2010 | Garmin Nuvi 660 GPS Receiver
I havew a Garmin nuvi. Yesterday I was driving
Check the fuse in the lighter end of the cord.....it may be blown and the unit is not getting power.
Oct 26, 2009 | Garmin nuvi 260W GPS Receiver
We have similar problem
Sep 03, 2009 | Garmin nuvi 260W GPS Receiver
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
May 31, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
311 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
