Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Bad color I have a 60" philips magnox that the color is going bad and its about 10 years old is there something about fuild in the tv that my need to be changed
The color multi points are off?
Posted on Dec 27, 2008
The screen seems to be pretty dark, like the color is off a bit. it's not as sharp as i remember it being
Chances are that you will need to change out the coolant fuild in Tubes Philips are well know for having Bad Coolant Fuild in the Green/Blue Tubes.You can remove the back and turn TV on Then Look down inside Tubes if picture is not Clear then coolant fuild is bad.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 29, 2011 | Philips 60PP9202 60" Rear Projection...
To much red. Can not adjust colors properly.
These sets are well know for having Bad Coolant Fuild in the Blue and Green Tubes ,you need to remove back and turn TV on and then Look down inside of each Tube if you can not see picture clearly then Fuild needs to be changed out. Mats Electronics sells Fuild 1-800-628-1118
Jun 26, 2011 | Philips 60PP9202 60" Rear Projection...
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
I want to make the tv have its original color brand new
Then remove old coolant fuild from green and blue Tubes and Put in New coolant Fuild Call Mats for Coolant fuild 1-800-628-1118
Dec 03, 2009 | Philips 55PW9363 55" Rear Projection...
I have a phillip magnavox that needs a color tube but I need the part number so that I can order it. The model number is 9p5534c103 can you help?
Which Tube is it that you need? Look on Encompass Parts Distrb. they have Blue and Green Tube Price is 204.46 1-800-638-3328 And are you sure Tube is Bad Most of the time they have Bad coolant Fuild that needs to be changed For projection coolant fuild,$6.50 a Bottle you need at least 4=$24.00 plus shipping With TV on and playing Look down inside top of ubes if you cannot see picture clearly then chage out the coolant Fuild.It means old fuild is Bad! Mats Electronics 1-800-628-1118
Nov 10, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
What are they talking about when they say you need to change the fuild in your tv. I have 60" philips magnvox that is about 10 years old
The projection TV sets have a coolant that surrounds the CRT picture tubes. It is used to keep them cool when they are lit up. After 5 or so years the fluid gets cloudy and needs to be drained and replaced. If you do it correcly your set will have the best picture you have seen in a long time. Check with the site www.TvRepairKits.com for the fluid and a photo instruction guide.
Phillips 60pp9401
This set uses two convergence packs that go bad and take with them a resistor or two. You will need a repar shop to get it fixed. If it's over 10 years old, I would suggest getting a new HDTV set as these sets can start going downhill fairly rapidly past this age. If that's not an option, the repair could run over $350 IMHO.
Dec 18, 2006 | Philips 60PP9401 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
