Question about Philips Magnavox 9P6034C 60" Rear Projection Television
What are they talking about when they say you need to change the fuild in your tv. I have 60" philips magnvox that is about 10 years old
  • Philips Master
  • 3,459 Answers
The projection TV sets have a coolant that surrounds the CRT picture tubes. It is used to keep them cool when they are lit up. After 5 or so years the fluid gets cloudy and needs to be drained and replaced. If you do it correcly your set will have the best picture you have seen in a long time. Check with the site www.TvRepairKits.com for the fluid and a photo instruction guide.
Posted on Dec 30, 2008
Phillips magnvox black screen and buzzing noise from inside of tv
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 17, 2016 | Philips 60PP9352 60" Rear Projection...
Blured picture
Most common cause of this is Bad Coolant Fuild in Tubes ,philips is well know for having to change the Coolant Fuild in Tubes mostly the Green and Blue Tubes.Hers how you will know when TV is on Look down inside each Tube if picture is not clear ,then coolant fuild is bad.
Jul 02, 2011 | Philips 51PP9100D 51 in. Television
The screen seems to be pretty dark, like the color is off a bit. it's not as sharp as i remember it being
Chances are that you will need to change out the coolant fuild in Tubes Philips are well know for having Bad Coolant Fuild in the Green/Blue Tubes.You can remove the back and turn TV on Then Look down inside Tubes if picture is not Clear then coolant fuild is bad.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 29, 2011 | Philips 60PP9202 60" Rear Projection...
To much red. Can not adjust colors properly.
These sets are well know for having Bad Coolant Fuild in the Blue and Green Tubes ,you need to remove back and turn TV on and then Look down inside of each Tube if you can not see picture clearly then Fuild needs to be changed out. Mats Electronics sells Fuild 1-800-628-1118
Jun 26, 2011 | Philips 60PP9202 60" Rear Projection...
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
I want to make the tv have its original color brand new
Then remove old coolant fuild from green and blue Tubes and Put in New coolant Fuild Call Mats for Coolant fuild 1-800-628-1118
Dec 03, 2009 | Philips 55PW9363 55" Rear Projection...
I have a phillip magnavox that needs a color tube but I need the part number so that I can order it. The model number is 9p5534c103 can you help?
Which Tube is it that you need? Look on Encompass Parts Distrb. they have Blue and Green Tube Price is 204.46 1-800-638-3328 And are you sure Tube is Bad Most of the time they have Bad coolant Fuild that needs to be changed For projection coolant fuild,$6.50 a Bottle you need at least 4=$24.00 plus shipping With TV on and playing Look down inside top of ubes if you cannot see picture clearly then chage out the coolant Fuild.It means old fuild is Bad! Mats Electronics 1-800-628-1118
Nov 10, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 60" rear projection needs warm up time
Sounds like your regulator ic is about to go, not an expensive repair but you have a good thought about buying a new set. If your fluid has never been changed I bet it's due also. Give the choice serious thought.
Feb 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bad color
the color multi points are off?
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
